ay guys just a quickie i have a vx v6 and was wondering if i have TWIN PISTON BRAKE CALIPERS i checked and looks like i dont but i dont really know about this sort of thing thanxs for the help
pretty sure you do man, my bro has got twin pistions on his s pak
Im 99% sure thats all they come with at a minimum, if you have anything else it would be better not worse. You could search ebay for the calipers and you'll get some pics there to compare.
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
SA JustCommodore Section
All VXs should have 2 piston calipers on front brakes but only 1 on the rear.
I could be corrected on this though!
wow thanxs for the fast reply guys i guess i do mine are the same as the pic from vl berlina sent me so thanxs again guys
ALL VT on have twin piston fronts,standard.
Bit off the topic but has anyone seen the front brakes on a series 1 AU? I've seen bigger calipers on motor scooters! Go holdens
When the VT was released, it was a lot heavier than the VS (about 150kg more) and everybody with standard VN-VS brakes would know how inadequate they were. Holden knew that the VT had to be equipped with much bigger and better brakes. Standard brakes were twin piston front, single rear, with larger diameter and thicker discs front and rear, even on a base Exec.
Sports and V8's brakes were beefed up again from the Exec standard. It's just a pity they didn't sort out the disc warping problem that has afflicted VT-VZ's from day one.
yes the vx has twin piston calipers and ABS brakes (Bosch 5.3)
Cheers.![]()
* RVN 355 *
