Results 1 to 5 of 5
Thread: How to remove fuel filter clips?
    Jan 2005
    VIC
    Default How to remove fuel filter clips?
    Hi all,
    Based on this thread in the VZ forum:
    How to DIY serivce
    Quote Originally Posted by fullaaa
    should have little green clamps on both side of the filter. there is a little latch thing on the connector that plugs into the nozzle, you should be able to get it off using your fingers but have a screwdriver handy just incase you need a bit of extra leverage.
    does anyone know how to to remove the clips on each side of the filter on a VT ?
    There's no green clips like the VZ and the clips on mine didn't come off easily. I wasn't going to stuff with it being a fuel line as I won't be able to drive the car if it breaks.
    I heard there is a special too you can buy from Repco (about 10 bucks) to remove the clips safely ???
    Thanks heaps !
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Push the clips towards the filter, squeeze the two tangs on the clip and then pull. Some effort may be required if they haven't been removed for some time.
    Don't forget to reduce the fuel system pressure by removing the fuel pump relay, then start the car and let it stall and then crank it over for a few more seconds.
    MY RIDE
    VX S2 S-Pac
    Oct 2005
    if u dont wanna buy the tool...i had no choice cos they had no stock at all the places n repco had no idea what i was talking about n said theres green clips on all (not true)
    Get a icecream container and cut a long strip and form a circle to go around the fuel line (keep triming it to get it the right size) then slide it under the metal lip and if u push it in far enuf it unclips the line when u go to pull on it.
    That was what i did for the fuel line where it comes into the engine bay, sounds like its the same tho
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by tyrefryer View Post
    The clips on the fuel filter lines are different from the ones in the engine bay, no special tool required.
    MY RIDE
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    before I removed the box in mine they were like the vn clips... stick ur finger under them n pull outward
  1. VT Fuel Filter remove?
    By Noy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-04-2008, 10:55 PM
  2. Remove Fuel Dampener?
    By Dan355 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-10-2007, 08:14 PM
  3. How-To remove trim clips.
    By The Darkness in forum Holden Commodore How-To's
    Last Post: 02-04-2007, 08:38 PM
  4. I need the small tool used to release the high pressure clips on a VT fuel pump......
    By speedotom in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-01-2006, 08:32 PM
  5. how to remove fuel pump please
    By VKnVLCalais in forum VL Holden Commodore (1986 - 1988)
    Last Post: 21-11-2005, 10:16 PM
