Results 1 to 4 of 4
Thread: Standard air conditioning control: illumination problem
    jazza15 is offline Jarryd
    1999 VT II S
    Jun 2008
    Eltham North, VIC
    Lightbulb Standard air conditioning control: illumination problem
    So yeah, all the lights except for the one for the A/C button on my VT II commodore's standard air con panel WON'T LIGHT UP.
    I checked fuses, fiddled around with the back of the panel and still nothing.
    Also to make matters worse, after un installing my nokia phone in car kit, i just cut the power cable for it and now my stereo won't turn on, I'm pressuming that this was wired up through my stereo's (aftermarket) power.
    Suggestions?
    ...or its gunna be a LLOONNNGGGG arvo tomorrow...
    adam69 is offline Banned
    VT Clubby
    Oct 2004
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Quote Originally Posted by jazza15 View Post
    Suggestions?
    As for the a/c control panel lights, its a very common problem. Just blown globes, when inspecting the removed globes from our vt they were ALL blown. Not cheap to replace either, probably better off putting LED's in there..
    Your probably right about the phone kit, I think the wire probably shorted out when/after you cut it. check the fuses under the steering wheel and insulate the cut wire.
    1999 VT II S
    Jun 2008
    Eltham North, VIC
    thanks, sorted it out, i connected the negative to the positive from the old phone kit wire and now it works.
    I'm probably gunna have to try that one with the LED's.
LinkBacks (?)
  1. 20-07-2008, 01:28 AM
  1. VT Air Conditioning Problem
    By agault in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-06-2011, 03:34 AM
  2. Replies: 0
    Last Post: 14-10-2007, 10:14 AM
  3. No Backlight Illumination on Climate Control VS
    By ivaninoz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-08-2007, 09:11 PM
  4. Climate Control, Illumination lights?
    By newo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-03-2006, 08:21 PM
  5. Interior illumination problem
    By VLtuff in forum VL Holden Commodore (1986 - 1988)
    Last Post: 11-12-2005, 06:23 PM
