I have a VX S (exec spec features) and when the A/C is on if the fan is set on hi on a warm day it will cut out intermittently.
Anyone had this b4? Ideas would be good because I'm out.
Sure it only happens when on full blast? you may find its a problem with the fan itself overheating and cutting in & out if so.
jam a thermometer down your air vents and check the temp.
Just maybe it is getting to cold so the fan is stopping or the fan speed resistor maybe sus.
