Results 1 to 13 of 13
Thread: VT-Engine miss's under load @ low revs
    VT Executive
    May 2008
    Alexandra,Central Otago NZ
    Unhappy VT-Engine miss's under load @ low revs
    When cruising at 100 kph then encountering a hill, the engine starts to pop & fart. I have to try & give it more to make it kick down. My fuel consumption is shocking. I tried replacing the spark plugs, the leads & even got a replacement coil which I alternated with the existing ones without success (thinking that 1 of them was breaking down).
    Someone has mentioned it could be the ignitors. Where are these located?
    By the way, I have a direct injected LPG kit & I run it on gas 90% of the time, the effects of the engine missing are a lot worse on gas compaired to petrol. I guess its just the bang caracteristics of the 2 fuels
    08 ve omega
    Jun 2008
    i had the same problem with my vx but i changed the plugs and leads but the problem went away maybe one of the gas injectors maybe blocked abit
    VT Executive
    May 2008
    It seems to run smoothly under acseleration though & I dont think its a gas issue as ive switched it over to petrol & the same problem is there.
    08 ve omega
    Jun 2008
    VT Executive
    May 2008
    I did 1 at a time, when there was no change I changed it over to the next 1
    08 ve omega
    Jun 2008
    id try with all new ones or maybe get the computer scaned to see what fault codes have come up
    VT Executive
    May 2008
    I had another look today & I think what I thought was a miss is actually the motor running slightly retarded. Im gonna get it scanned but I think the crank angle sensor might have gone.
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    what spark plug gap you running? have you tried a smaller gap?
    Body by Holden, Soul by Brock
    the Legend will live forever
    2002 Hyper VXII S
    Sep 2005
    I had almost exactly the same problem you mentioned in my VXII V6. Took all the plug leads off and re-attached them and it went away! Don't really know how it fixed it, but its gone! Was doing it for nearly 12 months and had it looked at twice by Holden with no success. Hasn't been back since!
    TUF UTE's Avatar
    TUF UTE is offline Dave
    05 VZ SENATOR
    Nov 2008
    adelaide
    would have been bad spark on yourss glenno, you just got lucky.... if you keep driving yourvt like it the way it is its probably going to blow a airbox soon
    SIR LS1
    the two ton go kart
    vt berlina series 1
    Sep 2008
    TUF UTE's Avatar
    05 VZ SENATOR
    Nov 2008
    adelaide
    the thing the airfilter is in , im guessing your not to familiar with cars mate... best to just take car to a mechanic and get them to look over it, pref. gas mechanic
    SIR LS1
    the two ton go kart
    fitz_vt's Avatar
    fitz_vt is offline Pass Me A Wrench.....
    VT Commodore SII Olympic Edition
    Nov 2008
    Adelaide - South Side
    your car seems to have too much air to LPG or Fuel mixture take it into your local mechanic for a tune, and maybe a bit of a service..
    |VT Olympic Edition 3.8L Ecotec | VY S Pack Green Interior|
    Mods to come | VY Map Reading light/Sunnies Holder|
    "Give me a minute, I'm good. Give me an hour, I'm great. Give me six months, I'm unbeatable."
  1. VY engine revs
    By madgamer2006 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 15-02-2008, 09:47 PM
  2. How to load engine on/off trailer?
    By Shounak in forum The Pub
    Last Post: 23-11-2007, 08:39 AM
  3. sputtering engine under load
    By blitzwurst in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-11-2007, 10:17 PM
  4. Engine struggles under load
    By Bz Kn33z in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-03-2007, 08:18 AM
  5. engine cutting out when cruising+under high load
    By gambit120 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 21-09-2005, 05:03 PM
