Results 1 to 11 of 11
Thread: larger brakes
    '97 VT ecotec
    Dec 2007
    Default larger brakes
    so my brakes need doing , but as im slowly doing mods to the car rather than just replaceing the standard brakes i was thinking of upgrading to larger discs and calipers . has anyone done this and what problems my i encounter ? my car is a 97 VT . cheers .
    minux's Avatar
    minux is offline Infidel Bear
    300rwkw FG G6ET/2011 Sti Spec R Hatch
    Mini Putt 2 Champion!
    Feb 2005
    What sort of driving are you doing? If it is just day to day, there really is no point updgrading caliper or disc size. Upgrade rotors and run better pads and leave it at that.
    "Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind."
    - Theodor Seuss Geisel
    VT
    Apr 2005
    QLD
    I know PBR do an upgrade kit, then there are mobs like Cebco, PWR etc etc... Depends on what you want and ultimately, your budget.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Slotted rotors and decent pads are all you really need.
    Visit my Facebook page
    '97 VT ecotec
    Dec 2007
    im not only looking for the stopping power but my mags are quite open and it looks kind of funny with the smaller discs , is there any thing i can do about that ?
    Kikki's Avatar
    Kikki is offline WA Cruise Moderator
    08 VE SSV Sportswagon & 98 VT Berlina Wagon
    Aug 2007
    Eaton, WA
    Um change your mags?
    Craig is doing his today, Slotted/Drilled rotors & Police Spec Brakes, fixed up a little with some caliper paint. I recon it will look pretty nice.
    Kikki's Avatar
    Aug 2007
    Eaton, WA
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    I got some 343mmx32mm fronts and 315mmx28mm rears. They're to suit VT onwards (I had to use hub adaptors) so perhaps look for something similar to what I purchased. 343mm definitely fills out 18"+ wheels compared to the standard 296mm VT brakes.
    VXII Berlina Sedan
    Jul 2006
    Adelaide, South Australia
    Quote Originally Posted by 1991_Vn2nV View Post
    Can you fit that sized rotors to standard VT / VX Calipers without any modifications?
    1991_Vn2nV's Avatar
    Mar 2006
    VT
    Apr 2005
    QLD
    Quote Originally Posted by f1_power View Post
    You will need an approved bracket to relocate the caliper further out on the radius to clear the larger rotor.
  1. Larger Rims on My VTS Stocks
    By nabed4t in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-10-2006, 09:57 AM
  2. larger t/b
    By stateo 304 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-09-2006, 09:28 AM
  3. WTB: extractors and larger exhaust
    By Fat VB in forum Swap / Wanted to Buy / Trade
    Last Post: 28-11-2005, 03:07 PM
  4. Larger fuel tank..
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-11-2005, 12:48 PM
