+ Reply to Thread
Results 1 to 7 of 7
Thread: Car Wont Start on 1st Crank But Starts on 2nd
    08 VE SS-V 6.0Lt V8 SEDAN
    Mar 2006
    Default Car Wont Start on 1st Crank But Starts on 2nd
    My Dad has a VT Wagon V6.
    It will not start on the first crank, but starts when you release and crank a Second Time. It does this every time. Cold or Hot.
    Changed the Plugs, Leads, Tested the coil packs for correct Resistances. Put BP Ultimate in and Put Injector Cleaner in as well. Cleaned out Throttle Body and Air Filter. Still happens.
    Checked all wires/connector plugs to all sensors around the engine.
    Once the Car has started it seems fine. No hesitation or missing and power seems fine.
    Anyone have any ideas on what it might be ???
    accentstencil's Avatar
    accentstencil is offline Donating Member accentstencil Maloo accentstencil Maloo
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Could be a fuel pressure problem. It may not be retaining the pressure after you turn it off. When you crank it the second time it then has been primed twice and builds up more pressure. Remove the vacuum hose from the fuel pressure regulator and see if you can smell petrol, if so replace it.
    MY RIDE
    Boonz's Avatar
    Boonz is offline the holden mechanic Boonz Maloo Boonz Maloo
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    sometimes the key readers dont get the correct immobiliser code form the keyhead and wont let the motor start the first time
    and the second time you crank it over it ignores the immobilser code and lets the motor start but it logs a fault code in the immobiliser part of the BCM
    a new slipring key reader and new keyheads usually fix the problem when it happens
    get your BCM checked for fault codes related to the immobilizer
    Vs series 2
    Oct 2007
    my vt s does this at the moment, ive found if i turn key to till electrics come up, wait for fuel pump to stop making noise, repeat this 3 times. then it starts first go, so i would say its the fuel pressure ill get it looked at.
    fitz_vt's Avatar
    fitz_vt is offline Pass Me A Wrench..... fitz_vt Executive
    VT Commodore SII Olympic Edition
    Nov 2008
    Adelaide - South Side
    Quote Originally Posted by Kizza00 View Post
    yeah sounds like fuel filter, pressure regulator or fuel pump seams to be the problem..... Definately something with fuel pressure
    |VT Olympic Edition 3.8L Ecotec | VY S Pack Green Interior|
    Mods to come | VY Map Reading light/Sunnies Holder|
    "Give me a minute, I'm good. Give me an hour, I'm great. Give me six months, I'm unbeatable."
    VT commodore executive
    May 2005
    Hi i have a problem i have been having the same problem with my car it doesnt always start straight away takes a few seconds but once it has started and i turn the car off it will then start straight away. i have just had the Fuel pressure line and the reg changed. but it still seems to be doing the same thing. also i dont hear and noise from the fuel running along the car as i have heard people been saying. can anyone help if they know the problem? thank you.
    Boltonator_VT is offline Recreational User :) Boltonator_VT Executive
    VT V6 Acclaim Auto
    Jun 2009
    Kumeu, Auckland
    Mine did this too. Nowadays I leave the key in the 'on' position for a couple of seconds before I start the car. I also have the habit of driving with my lights dimmed so when I turn the car on, they turn on immediately. When I do leave the key on the on position. I can hear the fuel pump whirr for a couple of seconds. I reckon its related to a loss of fuel pressure when the car is off.
    I never understood the sales of the Kia on the Holden lots here in NZ. I couldnt think of any cars that could be so different.
+ Reply to Thread
  1. Vl Berlina Just Wont Start. Crank Angle Sensor?
    By yogorilla in forum VL Holden Commodore (1986 - 1988)
    Last Post: 27-10-2009, 04:08 PM
  2. HELP!! VS 5lt Calais will crank but wont start
    By ashbox in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-08-2009, 08:29 AM
  3. vr wont crank over
    By back_in_a_vr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-03-2007, 11:56 AM
  4. VN V8 Wont Crank over when Hot
    By madA69 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-01-2006, 11:42 AM
  5. engine wont crank
    By Michaelgreenaway in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-04-2005, 10:23 AM
