Just a quick one, i'm pretty sure i have a cracked diff cradle...i got a mate to reverse the car slowly, and i could actually see the negative camber increasing. has any body else had this problem??? it just so happens that i just got a mini spool put in.
Where would i go to get it fixed???
Any help would be good, Cheers
jack the car up an inspect your irs cradle... Its not as common in cars that are just thrashed, but shifting way too hard and and minispools are not nice for them..
IRS cradles snap, i've done it, a couple times..
Originally Posted by garth
Def a common problem. Holden apparently rectified the **** IRS setup in VX somewhere.
Originally Posted by davway
VX series 2 think it was
so do i get mine welded up??? or should i just get one from a wrecker??? would the vx s2 go in my car??? wouldnt want it happen again.
just seen this
VX VY VZ REAR DIFF CRADLE CAMBER KIT 17" 18" 19" TYRES - eBay, Other Car Parts, Accessories, Car Parts, Accessories, Cars, Bikes, Boats. (end time 21-Jul-08 18:39:21 AEST)
if the vx s2 will fit, this would be a good buy yeah???? already has the camber kit installed, and is supposed to be stronger than a vt one
Looks like a good price. Might want to get him to send you pictures.
While your there, i'd still weld a plate over the top, if your planning to still drive spiritedly![]()
what i ended up doing to my last one an it lasted til the accident, clean it up with a drill & wire brush before fitting, weld in a plate or 2 on the irs cradle to give it strength..
cheers
mat
Id be interested to know if the VX2 cradle ect can be swapped for VT1 rear.
just had a feel around the top of the diff and i cant feel anything out of the ordinary, should i be able to notice it easily??? if its not the cradle, what else could it be? the camber seems to get slightly worse when reversing and when i turn corners i get some real bad clunks coming from the rear...
had a look at everything else under the car, nothing seems loose or worn, i'll take it to pedders tomorrow.
Whatever you do, DON'T go to pedders, at all. Your wallet will thank you for it.
Get a decent mechanic, and they'll be able to do whatever is needed to it.
If its only one wheel, and looks like the pics at the bottom, its def. the cradle. You will only be able to feel the crack at the top (roughly in the middle, branching out to the side with crap camber).
They crack right at the top, and on my car i could barely get my hand in there to fell it, would be easier if the car is on a hoist, so your not lying down when trying to reach up. It could be a collapsed spring, but thats very unlikely considering you said it only does it when reversing (which is exactly what mine did). You'll probably also notice the steering wheel is out abit now aswell, whilst accelerating, then straightenes up when rolling.
geez, my camber doesnt get that bad lol. ok so i'll find someone else, not pedders.
not a cracked diff cradle, went and seen a mates older brother whos had experience with the problem, he took it for a drive and got under the car to scope things out. i'll take it to kmart auto to get all the bushes in the rear done.
Haha, kmart are almost as bad as pedders.
Not sure how bushes give you more camber?
a mate of mine works for them, he'll get it done for a case + parts.
