Results 1 to 2 of 2
Thread: Help smoothing vx doors
    RUN41T's Avatar
    RUN41T is offline Go forth and modify
    Vy SS
    Jun 2006
    Wollongong
    Default Help smoothing vx doors
    Hey guys, Im in the process of removing the trim pieces halfway down the doors on my vx, and cleaning the grooves up. My question is weather or not i can fill the grooves to smooth the doors, will they need to be welded? They dont seem very deep so will a quality fibre bog do the job? Doing the job myself but dont want to use bog if it is just going to crack.
    Garrett
    RUN41T: Real cars don't power the front wheels... they lift them
    VE Berlina V6
    Mar 2008
    Wollongong NSW 2526
    if the prep work is top notch i shouldnt see why not. just need a really good contact between the bog and the door. if it doesnt have a good bite, i can see it cracking due to the vibrations through the door when it gets closed.
  1. Are VY ute doors the same as standard VY doors??
    By sokeefe1984 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 18-04-2008, 04:24 PM
  2. Smoothing boot garnish
    By Shortstuff in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-11-2006, 05:16 PM
  3. Doors???
    By cdawg in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-08-2006, 12:59 AM
  4. VN doors onto a VR
    By VR_Shift_84 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-10-2005, 10:23 PM
  5. Throttle body, porting/smoothing
    By greenfoam in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-04-2005, 08:30 PM
