Key remote is all ok but rubber boot over micro switches have split holden tell me a new remote needed and programed is this true or can i get boot replacement or a new learning remote as replacement or has somone got a spare remote to sell.suit vx. thanks
You can't just get the rubber buttons, a whole new key is necessary. They are glued together and difficult to pull apart successfully even if you could get the rubber buttons. You can get cheap remote keys on ebay but then they need to be programmed.
I know it sucks but what can you do, both my keys have the same problem. They should make the buttons so that they last at least the life of the battery.
MY RIDE
thanks i was hopefull
You CAN get the rubbers,there was a thread posted the other day regarding this.Ill try and find it.
here it is.Remote Key Buttons Worn Out
MY RIDE
I bought a complete genuine NEW 3 button key with blade off Ebay for $35, they are often available for upto $50. It of course requires programming / matching to the body control module (BCM), which I can do for you for close to nothing if you are in Melbourne. You can easily swap the key blade by removing the two screws.
i get brand new keys for the vx 40 brand new with programing its worth havin a spare key around for that price
i have the same problem, button is ROOTED but remote seems fine, not that old and dont want to buy another.
only thing i cant get the inside part of the screwed button out. any ieads?? anyone?
see the above ^ link...
I like my roo well done
