Results 1 to 9 of 9
Thread: Map Pockets on back of front seats
    andyos's Avatar
    andyos is offline Ozzie 98 Clubby
    98 VT CLUBSPORT 5.0L
    Jun 2008
    Wodonga Victoria
    Default Map Pockets on back of front seats
    Does anyone know how to remove these map pockets and replace them coz my drivers side one has been broken off and also had the inner plastic broken in half on the left side of the pocket?Looks like a screw comes through the plastic backing on the coulson seat.
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    They are held on by plastic clips. Just pull the pockets off, the clips will break but new clips are cheap to buy and are supplied with new pockets.
    Apparently you can get them off without breaking the clips but it's a bit of messing around.
    MY RIDE
    andyos's Avatar
    Jun 2008
    Wodonga Victoria
    VX S S2
    Dec 2007
    Laidley, QLD
    ya just push in and up the entire black plastic of the seat to take it off, push the clips together(they are split clips) and push em out the holes, or the easy way, just bust the clips lol
    mistaken's Avatar
    mistaken is offline ... pimpin it VT stylez
    VT
    Jun 2005
    I'd recommend visiting Holden and buying a few spare white clips, as you may break one or two during installation. They are about 50c each, so half a dozen floating around your toolbox doesn't break the bank.
    1 Firstly you need to remove the lumbar support dial (held by a circlip).
    2 Once the dial is removed, start removing the rear panel from the BOTTOM. The top has guides, and if you snap those, you're stuffed.
    3 The bottom panel is held by two white plastic clips, roughly 1/3 of the way in on both sides. Just yank them, let them snap, and replace them with the ones you bought from Holden earlier
    You'll be able to figure the rest out. Just a note, it can be a pain getting the bottom two clips to line back up when you're re-fitting the panel. This is where a few extra clips can come in handy!
    andyos's Avatar
    Jun 2008
    Wodonga Victoria
    andyos's Avatar
    Jun 2008
    Wodonga Victoria
    Just tried your instructions mistaken.However the lumbar support dial is harder to remove than i thought.I cant even see a circlip all i can see is a black moulded fitting inside of the dial and the plastic is too tight here to see what is inside of the cover.Please help....
    andyos's Avatar
    Jun 2008
    Wodonga Victoria
    Got it.I needed another pair of hands to turn the lumber support dial and hold it out a little then i finally glanced the circlip and prized it off.The rest was easy.Thanks mistaken again for your help......
    mistaken's Avatar
    VT
    Jun 2005
    yep forgot to mention, that circlip is hard to get to , gotta push the plastic covering inward, and pull a bit on teh dial....
  1. Wtb:vt Ss Front And Back Seats
    By thekid in forum Swap / Wanted to Buy / Trade
    Last Post: 04-03-2008, 07:00 PM
  2. how to replace pockets on Back of front seats?
    By VXXX in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-01-2007, 02:18 PM
  3. how do i Remove the back of the Front seats
    By Charg'd in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-01-2007, 11:56 AM
  4. Pocket on the back of the front seats.
    By vsmad in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-12-2006, 11:54 AM
  5. vx front and back seats in a vn
    By Cossack1977 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-02-2006, 09:23 PM
