yep, ya gotta remove the whole light(or you MIGHT have enough room to get a screw driver(phillips head) in there), there's a screw on top that holds the metal ring on, ya gotta undo that to get the glass out( be careful tho), and cos of the type of bulb, DONT touch it with ya fingers!!! use a tissue or you'll be replacing it far too sooner then u should, can get pic for ya if ya wanna know which screw to undo, but its pretty easy to know which one to undo. hope that helps.
LinkBack URL
About LinkBacks
