Results 1 to 13 of 13
Thread: supercharged V6 overheating??
    VP V6 BT1,VR 5.0l statesman
    Nov 2004
    sydney
    Default supercharged V6 overheating??
    hi, a friend of mine has a supercharged VX calais and was driving home the other night and it started beeping and when she looked at the temp gauge it was up on high but it dropped straight back down again and was fine for a few days then did it again and dropped then was fine for a few hourd the skyrocketed and didn't drop she was only around the corner from home so kept going and when she got home realised there was a big hole in the radiator. the problem is now there is oil in the radiator is there any chance it could be something other than the head or headgasket??? i got a quote from the local mechanic on a headgasket just incase and they want a minimum of $1600 but he said more than likely more...also the car has about 280,000k's on it!
    Mar 2008
    the only other way i could think of oil getting in the radiator is the transmission cooler , other than the obvious head gasket
    Nov 2004
    sydney
    i thought that to but apparently if it was the trans cooler the oil in the water would be a redish colour and it's a milky colour!!! it's probably not looking good for her????
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by lilkel View Post
    It doesn't look good. The only advice I can offer is, don't go back to the guy who quoted $1600. You can get a second hand motor with less kilometers for less than half of that.
    An expensive lesson learned, don't keep driving a car that is overheating.
    MY RIDE
    Nov 2004
    sydney
    he reckons if it wasn't supercharged she's get out of it for under $500 but says that majority of the time they crack the head and that it costs a fortune for the supercharged heads???? does that sound right to anyone????
    Commydoor's Avatar
    Commydoor is offline born in the FB era
    Vr Ss Blown
    Sep 2007
    Beresfield, NSW.
    Sounds like a good excuse for a ground up rebuild lol. Isnt that how it all starts.
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by accentstencil View Post
    I forgot it is supercharged so it will be a bit more expensive, but I think $1600 is still too much if it is the heads.
    MY RIDE
    VY SII HBD Calais L67
    Dec 2006
    $1500 is about right for v6 head reco and gaskets. 2 heads= more labour than the straight ford motor and hyundai l4s which are the most common head gasket customers.
    If the radiator is empty and the car was driven for a while it will most likely be the heads + sludgy oil throughout the engine oil galleries.
    Nov 2004
    sydney
    Quote Originally Posted by chargedvx6 View Post
    when you say $1500 for the heads is that supercharged heads or normal???????
    Dec 2006
    Supercharged and Ecotec heads are identical except for one thing. The supercharged heads have injector holes cut into the head whereas the Ecotec heads don't. Everything else is the same. You can buy a set of Supercharged heads from a wreckers complete for $300. Labour is what costs for that job.
    2002 VX Calais
    Apr 2005
    Gold Coast
    i wouldnt be going straight for the head gasket its more likely just the inlet manifold gaskets. the v6 motors rarely blow head gaskets
    Nov 2004
    sydney
    we don't want to drive it how it is and make it any worse whats the best way to check if it's the inlet gasket do i just see if theres water coming from anywhere around there???
    Nov 2004
    sydney
    i was told that the supercharged heads were shorter were they just bull****ting me???
  1. Overheating?
    By Troy711 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 10-07-2006, 05:54 PM
  2. Overheating
    By Turbo_dreams in forum VL Holden Commodore (1986 - 1988)
    Last Post: 01-04-2006, 09:37 PM
  3. overheating!!!
    By Holdenboy_VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-01-2006, 08:12 PM
  4. VT overheating
    By Malcolm Logan in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-06-2005, 07:34 PM
  5. Overheating VP
    By rodge26 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-12-2004, 02:59 PM
