Results 1 to 10 of 10
Thread: installing cruise control
    Jul 2008
    Default installing cruise control
    I have a vx series 2 exec its a ex cop car, im lookin at putting cruise control and power windows in, i have all the wiring for the power windows (already there) but for the life of me i cant find the wiring for the cruise control. does this model even have the wiring in the first place? please help!!
    Ve Calais V 6ltr
    Sep 2007
    ADELAIDE
    Quote Originally Posted by Snotty_vx View Post
    yep wiring is there mate just need the stalk and cruise box with cable and engage/disengage plug that goes behind Ur break pedal, electric windows needs a bcm upgrade. i have done both of these and works great
    Jul 2008
    Ve Calais V 6ltr
    Sep 2007
    ADELAIDE
    cheers mate thats wat i wanted to hear
    good luck man
    glad to help
    nicko's Avatar
    nicko is offline Carbon Positive - DO IT!!
    75 cruiser ute
    Sep 2007
    sa
    Quote Originally Posted by rvx 219 View Post
    hey mate, just got a shack at yorkes and i need cruise if im gonna be doing all that driving. How hard was it to instal the cruise, you think it will be any more difficult with the manual tranny?
    cheers mate
    no longer a hoon by association - the commodore is gone
    Ve Calais V 6ltr
    Sep 2007
    ADELAIDE
    Quote Originally Posted by nicko View Post
    cheers mate
    took me 30 mins the tranny shouldn't make a difference[ i don't believe] just change the hardest part is the actuator behind the break pedal man if ya get stuck I'm happy to help
    nicko's Avatar
    75 cruiser ute
    Sep 2007
    sa
    sweet as. Im just thinking ill need a clutch switch to disengage the cruise when i push it down??
    vx executive - Trumph TR6 - Toyota surf
    Jul 2008
    Tauranga NZ
    Hi I have a VX series 1 exec and have just installed electirc windows on the front, the only problem I found is that the drivers window didnt lower, the auto relay system wouldnt work so I traced the wire (green with black stripe) to the drivers footwell cut it and ran a new wire from there directly to the window regulator works fine but no auto lower.
    Also fitted the cruise control gear from a VT Acclaim - brake switch - cruise module - indicator/cruise switch but no go ! nothing lights up on the dash have tested all bits except the cruise module and they are ok if anyone can post the selftest details that would be great, other wise its down to the local dealer to get hooked up to the diagnostic computer.
    All the wiring was in place for the windows and the cruise I did not buy door looms as its only a matter of running two more wires from the body plug to the regulator.
    Ve Calais V 6ltr
    Sep 2007
    ADELAIDE
    Quote Originally Posted by topzone View Post
    did u upgrade ur bcm? i had that problem with the auto down new bcm fixed it. the cruise problem i had the same thing as well turned out i screwed the brake switch in to far adjust that see how u go! and when i hook the throttle cable up i hooked it wrong check that as well, also mode and up when turning the key hold for 3 secs and push mode to go throw ur display and test the cluster to see if it brings up the cruise lights! hope this helps ya mate
    Jul 2008
    Tauranga NZ
    Thanks for that I didnt change the BCM I am happy with the windows as they are.
    Still had no cruise light showing this arvo so I took it out and decided to have a play with the switches pressed the bottom switch in, still no cruise light showing ! then rocked the top switch back and bingo the active light comes on and shes away on her own ???.
    Im rapt that the cruise works but wtf is going on with the cruise light ?
LinkBacks (?)
  1. 19-10-2008, 04:38 PM
  1. installing cruise control help
    By hombsch in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-05-2008, 02:50 PM
  2. Installing Cruise Control...
    By 1991_Vn2nV in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-09-2007, 11:33 AM
  3. installing cruise control
    By slappa. in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-10-2006, 09:22 PM
  4. Installing cruise control
    By Hakka in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-02-2006, 10:02 AM
  5. Installing Cruise Control???
    By holdensupporter2005 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 10-10-2005, 11:34 PM
