97 VT 3.8L , have a strange gurgling/bubbleing nosie coming from around the plenum. never heard it be4 so im thinking somethings up ? any ideas ? cars running fine for the time being , no miss-fire , no oil leaks ect . im a little confused !
Maybe your inlet manifold is sucking in air/coolant? Loosing any coolant? Get a 700ml or similar bottle of water and tip a small amount where the inlet manifold and heads meet, with the engine running and see if the cars revs change.
cheers mack . what would be the course of that if it is the case ?
you would have to replace the inlet manifold gasket..
if that doesn't work though.. try the same thing but with some start you bastard
my bad forgot to add the word gasket lol
