Results 1 to 15 of 15
Thread: stalling but not...
    vx_ss_black's Avatar
    vx_ss_black is offline phantom vx
    vx ss
    Aug 2008
    campbelltown
    Default stalling but not...
    hey all issue with my car.. vx ss 01.
    anyway when the engine is cold is the only time it happens... when i let it sit and idle it sounds like the fuel gets cut off and then fed back in. like the revs will die but come back. it will also just sit there and rev itself. not much though. when im driving and this happens, it feels like the engine cuts out or the accelerator pedal is pushed in, but it aint. what the hell is going on with my car?
    could it be the knock sensor?
    OLS108's Avatar
    OLS108 is offline MR Helpful
    Stockish VX Berlina
    Mar 2005
    QLD
    has the car been tuned ?
    does it throw the engine light ?
    i would be checking the PCV valve hose that goes into the manifold behind the Throttle body for slips or a hole.
    could also be the 02's
    if its been tuned i would say its the tune.
    vx ss
    Aug 2008
    campbelltown
    nah hasnt been tuned yet. and yea it does do the engine light. ill check now for the holes...
    edit: doesnt look like there are any holes in the piping. bugger. my mechanic fixed this problem before so ill ask him what he did. hew said he replaced a hose of some sort. cheers
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Do an error code check. The light tells you it has logged a code.
    Visit my Facebook page
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Check the rubber joiner on the PCV hose, where the two hoses connect to one at the rear of the intake manifold. Actually they are plastic tubes and not hoses. Mine went the other day, causing high idling and it also triggered the engine light. If that is the problem you will need to buy the entire PCV hose setup, around $74. They do not sell the rubber joiner (of course). I bought a brass Y connector, a little bit of hose and modified it a bit.
    MY RIDE
    vx ss
    Aug 2008
    campbelltown
    it shows no error code when i use the diagnostic display on the dash. although i watched the temperature reading on the dash display when it started playing up and it was jumping between readings of about -60*C and 60*C. all over the place and changing quickly. argh this sucks
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by vx_ss_black View Post
    By diagnostic display I assume you mean the one accessed by the buttons on the trip computer. It does not display error codes. As far as I am aware the only way to read the codes of the LS1 is by Tech 2 or some other scan tools.
    MY RIDE
    vx ss
    Aug 2008
    campbelltown
    oh ok. bugger. i just hot earth kitted my car for 50 bucks! unrelated but i did!
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    It seems to be the only way to access the error codes.
    I would try cleaning the throttle body.
    Hot earthing is more a marketing ploy than an added benefit. It doesn't really do that much.
    OLS108's Avatar
    Stockish VX Berlina
    Mar 2005
    QLD
    mate where in aus are you ?
    its going to be your 02's mate, if you checked that hose and its fine.
    vx ss
    Aug 2008
    campbelltown
    im in campbelltown... 50 ks from sydney ish. how much will the sensors set me back? a bit strapped for cash atm. would that make the temp readings go haywire?
    i dont really mind that much if the hot earth doesnt do much. i dont mind placebos
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    I am also from the Campbelltown area. Go to Paul Wakelings to get your error codes checked. They are very good there and may do it for nothing, they cleared my codes for free.
    O2 sensors are about $150 from Holden, cheaper at Repco and Auto One but have the codes checked first.
    MY RIDE
    vx ss
    Aug 2008
    campbelltown
    awesome. cheers. i will drop in on monday. didnt realise they were that good. i heard only bad about em. i guess everyone has different experiences. thanks
    3.8L GT35 4runner/VK calais
    Dec 2006
    Nowra
  15. #15
    vx ss
    Aug 2008
    campbelltown
    thanks for the help guys. had a diagnostic check done by my mechanic. it was the coolant temp sensor. kept giving the engine bad readings so fuel feed was changed to suit the bad readings. replaced it myself. yay another DIY fix for me!
  1. VS stalling
    By BeastVS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-07-2006, 10:37 PM
  2. Stalling
    By robcom in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-03-2006, 09:52 AM
  3. My VN keeps on stalling! Help!
    By VNDAVN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-11-2005, 10:38 AM
  4. HELP, Stalling VT
    By Ian J in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-10-2005, 11:22 AM
  5. Need help with stalling vs
    By Sandman240588 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-10-2005, 11:28 AM
