Results 1 to 5 of 5
Thread: trouble starting vx ls1
    FORCED's Avatar
    FORCED is offline Huh Did Sum 1 Say FORCED?
    VX SS
    Sep 2006
    Noarlunga/Seaford
    Default trouble starting vx ls1
    i have a vx ls1 6spd when i try start it it ticks like the battery is flat then starts...other times i get nothing doesnt even try to start....but if i leave it for a bit it starts fine....and i can push start it ok aswell what could it be?? i was thinking battery/ignition module/neutral switch just drives me crazy
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by FORCED View Post
    Could be the battery or a bad connection. Try cleaning the terminals and check the connection of the large cable at the starter motor. The problem might also be the starter motor itself.
    MY RIDE
    vx_ss_black's Avatar
    vx_ss_black is offline phantom vx
    vx ss
    Aug 2008
    campbelltown
    a mates car does the exact same thing. although not an ls1, its a 626, im guessing it would be the same thing. starter motor solenoid. so yea like stencil said you are probably up for a starter motor
    minux's Avatar
    minux is offline Infidel Bear
    300rwkw FG G6ET/2011 Sti Spec R Hatch
    Mini Putt 2 Champion!
    Feb 2005
    Check the wire at the back of the starter motor, known for them to come off.
    "Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind."
    - Theodor Seuss Geisel
    FORCED's Avatar
    VX SS
    Sep 2006
    Noarlunga/Seaford
    was almoast certain it was the battery when it didnt start then started straight away with a jump start but i was wrong...was in town today and it did it again had to get a random to give me a push...when i turn the key its like something is sparking like a zap noise comming from under the bonnet was maybee thinking a relay...i know there was a fault with the series 1 relays and had to be upgraded???? dunno but its really starting to **** me...its hard when i cant get someone to look at it coz no one can pick me up from the auto elec!!
  1. Trouble Starting!!
    By jester419 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-06-2008, 09:00 PM
  2. Car trouble starting
    By glowworm in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-04-2007, 11:09 AM
  3. Having trouble starting
    By will in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-10-2006, 11:24 AM
  4. trouble starting
    By 16 vk boy in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 25-06-2006, 10:07 PM
  5. trouble starting
    By VN_BLUE_S-Pack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-10-2005, 01:50 PM
