Results 1 to 9 of 9
Thread: LSD Oil/Additiven - VT Super6
    nicko451's Avatar
    nicko451 is offline Nicko
    VY Executive V6 5Spd
    Sep 2005
    Default LSD Oil/Additiven - VT Super6
    just got some diff oil for my car and was told by my dad (previous owner) that there was a diff oil additive that i should put in to stop the clutch sticking! anyone know what the old mans on about???
    Cheers!
    A Car
    May 2004
    New Zealand
    Firstly are you shure you have an LSD ? (look for a small aluminium tag located on the diff, it will tell you)
    If so Refer below link
    ....................VX SS LSD oil
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    What oil did you guy ? Most already ahve it in it. Its the Sturacco. I got a synthetic oil with it in already, cause i wasnt sure if i had lsd or not.
    nicko451's Avatar
    Sep 2005
    dadem0n's Avatar
    dadem0n is offline The ex-LS1.com.au Member
    QLDSSC VT2 SS
    May 2006
    He'd be talking about "Friction Modifier". Even repco should stock it. Well worth throwing in.
    One of my old VTs had a really clunky diff and before I bought a new LSD, I tried some friction modifier (might have been Nulon brand?). Ran like new again
    nicko451's Avatar
    Sep 2005
    VX SS
    Jul 2005
    East of Melbourne
    Just had Holden change my diff oil and add the additive and also had the pinion seal replaced as apparantly the additive is not compatible with the old style seals and can leak given time, made a big difference to mine, no more chatter or clunks, see the attached Holden Service Bulletin below:
    LSD Chatter - The original oil and friction modifying additive used in VT and early VX commodores with LSD, can in some cases be innefective in adequately lubricating the LSD unit, depending on operating temperatures. GMH, in conjunction with SAA (Spicer Axle Australia, formerly BTRE), have revised the oil and additive used to help improve lubricating qualities.
    GMH use Mobilube SHC ID (1.5ltrs) in LSD units along with the revised friction modifier (100ml). They suggest no other alternative! The new oil and modifier requires the existing Viton material pinion seal to be replaced with a new Polyacrylic material pinion seal.
    Jul 2006
    The shell version is good. Is it the Spirax ?? There is a shell one with already the additive in in. This stuff is expensive but meant to be one of the best.
    I used Penrite Sin gear 80. I upgraded from a 80W90 to a 75W140 both $50 for 2.5 litres, so enough for flushing. Slightly thicker at operating. Its also fully synthetic with Esters, so this will swell any gaskets. Also its loaded with the max amount of diff chatter additive, dont need to add seperate. Castrol, Shell all have one like this, same as Mobil. Should not need to add anything to their top of the range stuff Castrol SAF-XA ......etc.
    The key is to use enough Additive to just shutt it up, as the additive is actually not beneficial as it caused it to slip more than it should and takes up lubrication eg less oil.
    Nov 2005
    penrite have an additive thats gold, just cant remember the name
  1. help with my VY super6 calais
    By darryl_kay83 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 23-09-2007, 04:49 PM
  2. VX calais super6
    By army in forum Vehicles For Sale
    Last Post: 26-04-2007, 10:54 PM
  3. super6 in vn
    By cuckoo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-07-2005, 09:36 AM
  4. VS super6?
    By savage1987 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-05-2005, 04:33 PM
  5. Super6 And Normal 6 Cai
    By zoidberg in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-05-2004, 11:36 AM
