Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Related > VT - VX Holden Commodore (1997 - 2002)
VT - VX Holden Commodore (1997 - 2002) Talk about anything relating to the VT - VX Holden Commodore.
Reply
LinkBack Thread Tools Display Modes
  #1
Old 13-08-2008, 10:25 PM
Ride: vt executive
delta-force Executive
Default my vt wont start?????HELP
It started 2 weeks ago my car would start but run really rough. It was like it was missing a beat, like one of the pistons were'nt firing. After 5-10 min it would run fine... if i tried to push the accelerator while driving or in neutral it would cough and splatter and would have no power this was before running it for 5-10 mins... as each day went it got worse and needed to be warmed up longer then it would run perfect.. now it wont start at all, it will kick over but wont run. if i push the accelerator it would cough and you hear thumping through the exaust pipe like its back firing has anyone had a this problem or similar????? just a note it seems to be same when i ran out of petrol once its like its getting no fuel... but that deosnt explane why it ran fine after it warmed up before....... please help........
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
  #2
Old 13-08-2008, 10:55 PM
Classifi3d Calais's Avatar
9-11-08 CRUISE FOR KEBAB
Ride: VE SV6, 52 Morris Coupe
Classifi3d Calais Berlina
fuel pressure regulator or injectors maybe? Id say its a fuel issue, if its cured by heat then look for something that gets quiet warm.
Listen to the injector pulses and see if they 'click' at the right times
  #3
Old 18-08-2008, 04:18 PM
Ride: 1998 VT Acclaim S1
Trade Rating: (0)
ACEMonkey Executive
Check your spark plugs, and get your spark plug leads tested. If they are ok, check your ignition coil pack. It could be on its way out.
  #4
Old 21-08-2008, 04:36 PM
Ride: vt acclaim
chipndale Executive
ignition module or fuel pump,
check for spark at all plugs,
and a fuel pressure check,
i had both go at the same time..
bummer
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Thread Thread Starter Forum Replies Last Post
VT v6 wont start? Soybean VT - VX Holden Commodore (1997 - 2002) 4 04-03-2007 07:50 PM
vn wont start william19 VN - VP Holden Commodore (1988 - 1993) 0 02-03-2007 09:57 AM
VX wont start _VX_S_ VT - VX Holden Commodore (1997 - 2002) 3 02-02-2007 02:50 PM
The VN wont start! Indy_387 VN - VP Holden Commodore (1988 - 1993) 14 24-07-2005 11:27 PM
Help wont start kasey375 VN - VP Holden Commodore (1988 - 1993) 17 07-05-2005 04:16 AM
Debt Consolidation | Xbox Mod Chip | Bollywood India forum movie reviews | The eBay Song | Loans | Car Reviews
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
