Results 1 to 18 of 18
Thread: Identity crissis
    Snerty is offline Snerty
    VK Calais LV2 M21 GU4
    Aug 2008
    20 ks east of the melbourne poo farm
    Cool Identity crissis
    I have a 1998 Acclaim which was given to me by my employer. It was a company car that had been depreciated well past it's value and dented on most panels, still, only 210k on the clock. The problem is that one of the former employee's was planning a bit of a shifty and removed the I.D tags...All of them and then lost them before he could use them for his dodgy dealings .
    The tag behind the L/H front indicator is still there but (as it has been sugested in other posts I have read) it isnt the v.i.n no.
    Now the problem... I am respraying it a different color and fitting a supercharged V6 . Does this mean I have to change the computer because I believe the computer codes are the only thing that can identify this car...The prefered option would be to re-chip the computer.
    Or ...With the right equipment, could the new computer be programmed with the old codes?
    VX S S2
    Dec 2007
    Laidley, QLD
    so he also took the plate out from under the windscreen on the passenger side??
    also, if you know the owner previous to this other guy removing the tags, they should have an old set of rego papers, this should have the VIN number on it
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    if its registered you can get the vin no off the sticker or go into vic roads
    the vin nos also in the windscreen on the passanger side
    as for the ecu, just swap the memcal with a supercharged one or "re-chip" it
    hope this helps
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    All sounds a bit dodgy to me. To avoid any 'heart-ache' further down the track, why not get in touch with Vic Roads and arrange for them to inspect it. Regardless of what you say, I reckon you've got a suspect 'stolen/rebuilt' vehicle. If you don't get it checked and validated and are stopped by Police, when they check for identifying marks etc and there aren't any they are very likely to impound the vehicle until they are satisfied it is 'legit and all checks out OK. I suspect that you will also have problems with the annual vehicle inspection if they can't match VIN etc with paperwork.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    The number behind the blinker is the BODY No. or Serial No in the VIN.
    The VIN will be like this.
    6H8VTK69HWL###### The Body No will be between L262500 & L371100 (Approx)
    Replace 69 with 35 if its a wagon.
    The Acclaim was based on the Executive so will have a K after the VT.
    and 3 Dangerous non ABS VN's
    Astranomical's Avatar
    Astranomical is offline Ecotec just kicked in yo
    Hammerhead Eagle i-Thrust
    Apr 2004
    Dee Why, NSW
    Have you checked the floorpan? I don't know if VTs have this, but I know VY/VZs have the VIN on the floor pan on the driver's side. Move the driver's seat all the way back and you should find a slit in the carpet. Like I said, i'm not sure if VTs had this, but in a VY/VZ, you can lift this bit of carpet up to reveal the VIN number.
    However, this still may not help - VTs may not have had this, not to mention that even if they did, someone could've sanded it off.
    Quote Originally Posted by som
    i saw a camira a while ago that wasn't blowing smoke.it was on the back of a tow truck.
    VX Executive S2
    May 2006
    Frankston South Vic
    Definately get it confirmed by Vic Roads or the police before spending any money.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Read the original post like this:
    "I've stolen a car and want to rebirth it, where are all the ID tags and what are they so I know what I am looking for".
    Visit my Facebook page
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Hmm mmmm.
    The body number will still give it away! It's on just about everything in the car
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Just sounds sus, basically no posts, and he wants to know this.
    vz wagon
    Aug 2006
    Wild west of Melb
    Quote Originally Posted by goVZ View Post
    No the vt's dont have this.
    VT Calais V6
    Aug 2007
    I'm with you on this. Reading he's other posts he has three cheap vt cars. Either he has stolen it or bought it stolen in my opinion, sorry if I'm wrong.
    gottavecalaisv's Avatar
    gottavecalaisv is offline Calais' are great mate!
    Ve Calais V V6
    Jan 2007
    sounds very suss to me, maybe he is a car thief? don't give him any more info just in case!!
    Aug 2008
    Default ID Crisis
    LOL (Snerty) I wish it were that easy
  15. #15
    Aug 2008
    LOL Funny as...If you have to ask how to re-birth a car...you are definately in the wrong buisness. Thats what the previous driver was attempting to do.
  16. #16
    Aug 2008
    Definatly wrong...However you are forgiven...My ex wife said the same thing
  17. #17
    Aug 2008
    Yes, he removed the winscreen and took the tag. I can get the vin off the rego lable...It's stiil registered, but that still didnt help me prove the cars ID... Anyway, the tag behind the indicator and engine number was sufficiant proof for vic roads so no prob now
  18. #18
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Good to see you are legit. Not all first time posters are. Apologies.
  1. 1992 Vp Fuse Identity Numbers???
    By Cobez in forum Electrical Wiring / Questions
    Last Post: 01-05-2007, 10:17 AM
  2. Identity Tags
    By Brasstard in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 24-01-2006, 08:55 AM
Tags for this Thread
