Results 1 to 7 of 7
Thread: the dreaded plastic door strips
    VX Executive S2
    Jul 2008
    Default the dreaded plastic door strips
    where should I go to get these stuck back on? the small one on the drivers side has come off and the drivers door one has pretty much almost ripped off. I read that the black stuff holding them to the paint is pretty damn hard to clean off, and I dont have any glue or trust in my aligning skills I was thinking a crash repair joint? or maybe a regular auto place could do it easily enough?
    nicko's Avatar
    nicko is offline Carbon Positive - DO IT!!
    75 cruiser ute
    Sep 2007
    sa
    i spoke to a few panel shops about it and they wouldnt take my black strips off and then work the glue off. They said they would rip them off hack the crap out of the glue then respray to doors and gaurds. So they said it would be $1300+ to get it done. You can have a go at it yourself with a caramel wheel and a fair few man hours though. I did one side of my car then i ended up getting it resprayed and leaving the strips off
    no longer a hoon by association - the commodore is gone
    VX Executive S2
    Jul 2008
    Thanks for the info, I am going to keep the strips on, and possibly get them painted at some point. I actually just want to re-attach the front 2 as it looks crap now with the missing plastic and black blobs :P
    maybe I should just ignore the pointless blobs that will be hidden anyway and put the fresh glue at the other points.. since if I do get them stripped off they will hack it up and respray it anyway.
    So the question now becomes, what glue should I use for the blobs.. And how to clean off the double sided tape residue? OR where can I take it that can do it for me for cheap
    nicko's Avatar
    75 cruiser ute
    Sep 2007
    sa
    whats on there itsnt actually a "glue" its a resine that it pretty much a slightly flexible cement. To get it of you need a caramel wheel ( about $15 from a paint product supplier, i got mine from a shop on George St, Norwood for 13 each) That goes into your drill and it spinds around slowly rubbing the cement away. That same shop will be able to supply you with the resine to stick them back on. If you have any problems finding a number for that place shoot me a pm and ill have a dig for you
    VX Executive S2
    Jul 2008
    nicko's Avatar
    75 cruiser ute
    Sep 2007
    sa
    Crash Supplies Pty Ltd
    22 George St Stepney SA 5069 - map
    ph: (08) 8132 9000
    send to mobileadvertisement
    Give these guys a ring, thats where i got my stuff
    VX Executive S2
    Jul 2008
    Cheers, will give them a ring
  1. door strips around car??
    By aza1187 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-05-2008, 12:52 AM
  2. Help removing plastic door strips
    By dean_jely in forum VY Holden Commodore (2002 - 2004)
    Last Post: 30-11-2007, 08:34 AM
  3. Door Plastic Strips Just Fell Off......
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-10-2006, 09:10 PM
  4. advice... plastic window strips
    By silver88vl in forum VL Holden Commodore (1986 - 1988)
    Last Post: 19-07-2006, 09:59 PM
  5. plastic door strips.... ?? which models ??..
    Last Post: 21-04-2006, 09:16 PM
