Results 1 to 5 of 5
Thread: t5 5 speed in a VX ecotec
    galeryz213 is offline galeryz213
    VX Executive S2
    Mar 2008
    Default t5 5 speed in a VX ecotec
    I currently have a VX ecotec auto and i needed to find out if a t5 gearbox out of a VS ecotec would fit. can any one help?
    VX Executive S2
    VZ monaro front end, GTO rear lights, VX SS rear bar & side skirts, 18" deep dish Apec rims, 18% tint, crystal side indicators
    SUSPENSION: D2 damper and height adjustable coil overs, RDA drilled and slotted gold rotors, Green stuff brake pads, Whiteline strut brace
    ENGINE: Port & polish heads, FIT 1.9 rockers, polished twin TB plenum, port & polish 71mm AFM, Pro racing series 10mm top gun ignition leads, FIT laser cut heat shields, lukey cat back, manifold heat insulator
    VP Executive R-spec
    Jan 2005
    Yes fits, you might need a home made gearbox mount but they are available since the saloon cars currently run this setup
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    You will need to do somthing to convert the t5 to a hydraulic actuator as they are cable driven. You might be able to make a bracket up and mount the actuator off the old gbox onto it.
    I have searched high and low for somthing specific to fit but have had no luck, you will have to modify and make somthing to fit.
    Reaper
    VP Executive R-spec
    Jan 2005
    If you call these guys http://www.ppgearbox.com.au/files/pd...20May%2007.pdf
    Pfitzner Performance Gearbox
    They might know who makes the parts since they supply the straight cut gear set for the saloon cars T5's
    VX Executive S2
    Mar 2008
    Thanks for the info everyone, i think il go for the getrag instead sounds a lot simpler.
    VX Executive S2
  1. Fluctuating idle on deceleration in 3.8 V6 auto (ECOTEC and non-ECOTEC)
    By cliffo78 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 25-04-2009, 12:02 AM
  2. Vr 5 Speed Ecotec Question
    By fitzy2005 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-08-2008, 06:38 PM
  3. ecotec idle speed adjustment
    By Panama in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-10-2007, 08:17 PM
  4. vn 5 speed versus vs ecotec
    By canb_vn06 in forum General
    Last Post: 28-06-2006, 12:07 PM
  5. blue 253 4 speed manuel swap for 3 speed trimatic and 202
    By quick202 in forum Swap / Wanted to Buy / Trade
    Last Post: 05-10-2005, 11:12 PM
