Results 1 to 7 of 7
Thread: VT Commodore Series II Question
    Aug 2008
    Default VT Commodore Series II Question
    im not sure if this is the right place to ask, but im thinking of buying a Series II VT Commodore, the only issue is the glovebox is broken, it sits in fine but once you try to open it it falls off, any ideas of replacing it? costs involved? thanks in advance
    coasty's Avatar
    coasty is offline the voices told me to
    vz equipe & vt berlina both v6
    Feb 2008
    kanwal nsw
    Aug 2008
    Quote Originally Posted by coasty View Post
    theres a pin that holds it in. look to see if its there
    Nope its not there, just an empty hole on either side, im guessing thats bad? if there is no pin to hold it would it be expensive to get a replacement put in? would the dash have to be taken apart?
    Kind Regards
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    When fixing my car i had a broken one also, I bought one from the wreckers, And had my repairer do it, I just couldn't come to terms with doing it, I found it to hard.
    And yet i have replaced most of my dash myself, And that stuffed me up.
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    If it is the right hand side that hangs then it just a matter of replacing the plastic pin. It couldn't be too expensive. It is very easy to insert a new pin, nothing needs to be dismantled.
    MY RIDE
    carless for now
    Feb 2007
    perth,Western Australia
    i had the same problem its a rubber knob thing.take the glove box out and you should notice a rubber thing missing on the right side
    adam69 is offline Banned
    VT Clubby
    Oct 2004
    The glovebox is two pieces screwed into one,if pins are broken then buy a new one and replace it,its that simple.
    If its broken where it fits into the dash then that part is avail too.It takes a bit of work to change but far from difficult.Both those parts i mentioned will cost you about $50 from Holden.I needed to replace them when i got my VT,just be careful refitting the glovebox as the pins are fragile.
  1. vn series one coolant question
    By taskmaster in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-08-2008, 11:18 AM
  2. Convertting to a series 1 engine from series 2 AND question about oil pick up
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-10-2006, 07:37 PM
  3. vp series 1 or 2 (Noob Question)
    By MarzVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-08-2005, 10:54 AM
  4. How to tell the difference between a Series 1 and Series 2 VX Commodore
    By ForceX in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-07-2005, 07:54 PM
  5. VN SS Series 2 question ...
    By ElDubya in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-07-2005, 02:29 AM
