Results 1 to 8 of 8
Thread: Help with Fuel Gauge problem...
    br14nh's Avatar
    br14nh is offline Back in the saddle....
    VX V6 wagon 5sp Manual
    Aug 2007
    SW Sydney
    Default Help with Fuel Gauge problem...
    Have searched this but can't find info I need; Does anyone know how the Litres in tank is read - is it the sensor, or is it calculated from usage?? If it's the sensor, then I have a doozy of a problem...
    The car (VX 1, executive manual V6 wagon) has been running normally in respect of the electrics for at least a year (haven't owned it any longer than that ); after I parked facing up a slight hill, (I knew I had a little under half a tank of juice) - when I got back in & started the car, the low fuel warning activated and display (single window) switched from "trip meter" to "distance left before empty", showing 4Kms. I went about 100 metres & pulled over, switched off completely then switched on using the "up" & "mode" buttons to get me the diagnostic info - cycled through readouts to find it was reading ~30Litres in the tank, which was about what I expected (?!?!)
    The Fuel Warning was still active even after this off & on sequence; then I switched off & on to get normal display back, low warning still active, but fuel gauge verrrrrrrrrry gradually climbed back over the next 5 minutes to where it should have been..... WTF?? Haven't driven the car since, but will keep an eye on this now...
    1) I would love to know why this is happening but suspect the cause won't be known...
    2) How can the Litres read accurately on the display window in diagnostic mode, yet the gauge reading is screwed ?!?!?! - and then gradually changes back to what it should ?!?!?!?!?! - Hopefully a Holden Tech-savvy person can answer that one!!
    I have EFI Live on my laptop which I'll be hooking up tomorrow to see what DTC's (if any) exist...
    Cheers,
    Brian
    KiWi1's Avatar
    KiWi1 is offline 11.00@126 Miss dat ****
    Dead 11sec VX SS, Defected VP Ute
    May 2008
    HIGGINS RACE DEVELOPMENTS
    Could be the fuel sender. They tend to go. Was a recall, maybe you missed it?
    Dont forget it is a Commodore.
    Also, they pick up is at the front, so that could be a why it reads low, on the hill.
    I know i had to run at least 1/2 a tank when racing, to stop fuel surge. 1.50 60' can cause many a pickup problem BOOM!!
    VL EXEC
    Aug 2008
    perth wa
    its a sensor in the tank so when its at an angle is missus the tank and does a basic calculation same stuff happens in my mates vz when the computer trips and realizes what happened it fixes itself plus the computers r always faulty many guys on the forum r finding its way out on the digital gauge and thats in there vy's n vz's hope that kinda helps
    I've driven fast cars I've done stupid shit in them each time i seem to come out on top i love you guardian angel
    vp ss 3 months to go
    Snap-on's Avatar
    Snap-on is offline Boilermongrelin
    82 VH, 99 VT Wags, 03 VY S
    Apr 2008
    Brisbane, Northside
    Yeah i've had this problem in my Vt aswell. It does settle down soon after. Also when the tank is low it can have a skits sometimes
    VT Ballin'
    br14nh's Avatar
    Aug 2007
    SW Sydney
    Thanks all, reassuring to know.... what I still don't get though is why the gauge tells me it's empty, but the diagnostic readout says the right amount (30litres)?? - If the gauge is following the sender, how is the 30 litres being measured?
    VE SSV MY10
    Jun 2006
    Hope this explains things
    the gauge has been calibrated to not fluctuate when cornering so if you had parked on a hill for a period of time when restarting the car will show less fuel as the gauge thinks there is less fuel the diagnostics is a instanced read out if you where to park in the same spot and go into diagnostics it would show about 6_10 liters on the display this also applies to adding small amounts of petrol to under 20liters wont show up right away
    br14nh's Avatar
    Aug 2007
    SW Sydney
    Got it now, thanks...... from that, it seems the delay on the gauge is a bit extreme.... oh well, at least I know it's behaving "normally"... for a Commodore...
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Just read the book, And illlusion is spot on.. Takes 10min to read because of the cornering, Thats so it wont go up and down and make it seem as though it's lost fuel fast.
    It's a good idea, In the VP it can move and shock you, The VT's onwards are designed tyo not register movement cornering hills etc.
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
  1. Fuel Gauge Problem
    By Brocko in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-06-2008, 05:12 PM
  2. lpg fuel gauge problem
    By fullymetal in forum General
    Last Post: 10-05-2007, 12:00 PM
  3. fuel gauge problem
    By craigvl038 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-04-2006, 10:47 AM
  4. Fuel gauge problem !!
    By kowan in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-03-2006, 11:47 PM
  5. Fuel gauge problem.!!!
    By shiftyvin in forum VL Holden Commodore (1986 - 1988)
    Last Post: 20-07-2005, 10:05 PM
