Results 1 to 4 of 4
Thread: VT2 factory immobiliser
    HSV GTS Commodore VT2
    Aug 2008
    Question VT2 factory immobiliser
    i've got a HSV GTS VT2, factory immobiliser has developed a fault after replacing battery..
    anyone know how i can get the car started so i can get it to a dealer for repair or what part to replace if this is something i can do myself?
    thanks all.
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Suggest you check all your fuses and reseat all the relays. When you say the immobiliser has developed a fault, what sort of symptoms are you getting?
    Aug 2008
    all fuses and relays checked..
    no fuel pump or starter when switching ignition on, after 10 secs, 3 beeps from behind dash.
    this is definitely the factory immobiliser.
    i just need to get it going to take it to a dealer for repair.
    vt 3.8 ltz
    Aug 2008
    after switching on the switch press the unlock button on the topo of the trip computer menu but the led will stop flashing then u can start the engine
  1. VP V6 Immobiliser
    By Hillerus in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-04-2008, 12:31 AM
  2. immobiliser
    By crg07 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-04-2006, 03:27 PM
  3. VS immobiliser?
    By sc88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-07-2005, 11:05 AM
  4. immobiliser
    By ducatis in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-07-2005, 05:38 PM
