Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Related > VT - VX Holden Commodore (1997 - 2002)
VT - VX Holden Commodore (1997 - 2002) Talk about anything relating to the VT - VX Holden Commodore.
Reply
LinkBack Thread Tools Display Modes
  #1
Old 25-08-2008, 09:09 AM
Ride: VT Exec 3.8V6
MattVT Executive
Default VT hot warning.
Hi everyone.
Had a problem heading home from work the other night.
The hot warning dash alarm came on and the temp gauge started heading toward the top. Not wanting to do any damage I pulled over and got a tow home from the roadside assist guys.
Looking under the bonnet it appears that the was some coolant leaking from some where and appeared to be sprayed up underneath the bonnet near where you check the coolant level.
Haven't had this car long. Anyone know of anything that might be the cause that could be an easy fix?
Got it converted to LPG about 2 weeks ago which has been going great. My mate and I could smell a little bit of LPG for a few secs, for the first and only time since the conversion was done, about 2 kms before she went hot?
Thanks in advance for any help or ideas.
Cheers.
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
  #2
Old 25-08-2008, 10:02 AM
Fr3ak+--'s Avatar
Closed On Monday
Ride: Vt Exec 5 Speed
Trade Rating: (0)
Fr3ak+-- Executive
at a guess you aren't using the right coolant and its boiled
flush the radiator and put in some new coolant and make sure it is v series rated or it will happen again
  #3
Old 25-08-2008, 10:31 AM
Ride: 1998 VT Acclaim S1
Trade Rating: (0)
ACEMonkey Executive
As above response or check your radiator cap is the correct one for your car. It could also be you may need a new radiator cap.
  #4
Old 25-08-2008, 10:36 AM
Ride: 1997 vt v6 wagon
Trade Rating: (0)
pablo Executive
"at a guess you aren't using the right coolant and its boiled"
The coolant shouldn't get so hot that it boils under normal driving conditions!
... provided the system is full, even plain water will suffice.
Take it back to the LPG installer pronto.
Pablo
  #5
Old 27-08-2008, 10:59 AM
Ride: VT Exec 3.8V6
MattVT Executive
Default Looks like LPG was the problem.
Had a day off today so did some trouble shooting.
Filled up the radiator.
Ran the car on petrol for a while looking for leaks and checking temp. Everything was normal.
Turned off engine for a bit.
Started on LPG for a minute or so. Coolant frothing out the overflow. Smelling of LPG. So LPG definitely the culprit here.
LPG getting into the cooling system.
When installing the LPG they connect it to the heater hoses and run water through the converter where the liquid becomes a gas before entering the engine. The water stops everything from freezing which would eventually stop the LPG from getting to the engine.
This only the only place where the LPG and the cooling system meet so problem solved!!
Taken it back to the LPG guy, drove 20k there happily on petrol, they are going to replace the converter.
Thanks for those who posted.
Thought I would post this in case anyone else ever has the problem.
Other than this issue, LPG is great. Save $50/wk running on gas....
Cheers.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Thread Thread Starter Forum Replies Last Post
air bag warning VT_WA VT - VX Holden Commodore (1997 - 2002) 12 07-07-2008 01:08 PM
Warning kowan Jokes/Humour 4 20-09-2007 11:47 AM
hot warning came on! mrVT VT - VX Holden Commodore (1997 - 2002) 9 20-02-2007 10:03 AM
warning statement VR - VS Holden Commodore (1993 - 1997) 6 15-03-2006 07:14 PM
Problem Mortgage | Debt Consolidation | Web Games | Psychic Readings | Debt Consolidation | Car Reviews
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
