Have a look in the car audio section ,should be of some help.When i done my sons car (it's an auto ) i ran it through the rubber gromet on the drivers side just below the brake booster where the clutch pedal should be. I just cut an x in the rubber , used plenty of dish washing liquid to lubricate it and pushed it through ,then ran it down the drivers side under the carpet
__________________
If you can't be a good example -- then you'll just have to be a horrible warning.
