head gasket kicked the bucket last friday.. car was at the mechanic until yesterday.. i got it back and the car was driving better than it has been in ages (which i guess means the head has been cracked for a while and just **** itself last week)
anyway.. i've driven the car about 35k's is i got it back.. all slow, and it was driving sweet, but this evening i went to take the car out and it was idling rough as hell. it feels almost like it did before the gasket stuffed up last week, except not completely as rough.
I checked the radiator to make sure there was water (it was full), then i noticed a cable was unplugged. It runs into the bottom of a cylinder shaped like a pen, to the right of the radiator cap.. could this have anything to do with it?
also checked the oil cap.. it was creamier than tub of yoghurt.. and there were threads of some sort in it?? but im guessing all that could be stuck on there from before..
could that unplugged cable have caused any of this, or are we looking at the same sh!t all over again.....
thoughts?
told the mechanic yet?
take it back first thing in the morn.
Yeah, sometimes its left over gunk in the system. But he should have flushed it and it would have collected in only 35ks. You should have warranty for it at least this soon. Now the threads, what to you mean ? It is like brown stuff ? Could be radiator sealer/capsules. More info thanks.....
did the put new oil in??
maybe they didnt bleed the cooling system and just blew another headgasket
how much was the replacement cost out of curiosity?
I find it hard to believe a V^ needed the head gasket done in the first place. I have only once done a cracked head on any Commo V6 in my 16 years as a mechanic.
But I do a HELL OF ALOT of intake manifold gaskets as this is more often than not where they leak and let water into the oil and oil into the water.
The commo V6 doesnt suffer from head gasket problems too often. It is usally misdiagnosed by many mechanics.
what would cause water to go from radiator through exhaust system and not leave oil in water or water in oil just curious as i know someone who has this problem and was told head or head gasket
to o.p has the car been back to the mechanic who fixed it, if so what do they think the problem is with your car
Same thing happened to me and it was the manifold gasket, tell tale signs are excess steam out of exhaust first couple of ks and sometimes when the water gets in the cylinder it's hard to crank over (like flat battery)
regards
keith
If a head gasket leaks near a head water port then the exhaust gases can get pumped into the cooling system every time the cylinder fires. After the cylinder has fired and sent hot gases into the coolant causing the coolant to boil, the coolant builds up pressure like a kettle, then as the piston goes down again the built up pressure in the cooling system squirts coolant back into the hot cylinder and creates steam that escapes and condenses in the exhaust on the next exhaust stroke. That is the water you see coming out the exhaust.
Disclaimer For The Reader ::
The information I provide is freely given to ONLY help you with thinking on problem solutions. IT IS NOT a "How To Do It Guide".
If you read ANY of my supplied information and use ANY of it you must accept and agree to do so AT YOUR OWN RISK or do not use the information at all.
I accept NO liability if you damage your or anyone elses property or cause any harm to yourself or others with the information provided.
I am NOT a Mechanic. You have been warned.
update on the problem?
car must have died...
1995 Manual HSV Clubsport
1991 Supercharged VN Berlina
Im currently trying to figure out the same problem, just replaced the headgasket due to it rusting through from previous owners not changing the water, now it has a consistant miss on cylinder 2 at idle
above about 1000rpm its gone, but 90% of the time at idle its missing, unplug cylinder 2 injector and the engine note barely changes.
can hear the injector ticking over, and there is spark, sparkplug is good, so whats next?
a vaccume leak couldnt cause a miss this consistant could it?
