Results 1 to 3 of 3
Thread: oil leak
    executive vt 5.0lt
    Feb 2005
    west suburbs
    Default oil leak
    i gave my vt a oil change, and while underneath the car, i saw that the power sterring was leaking. is there a fix ,or is the rack stuffed ,if so can it be done by myself,looks a big job how much for a reco rack thanks
    eko's Avatar
    eko
    eko is offline 3kO
    Soon to own vb commy end of year
    Aug 2007
    South Eastern Suburbs
    depends mate if ur leaking from the reserviour round da not so expensive from wreckers if ur leaking from hoses 20 buks from auto barn if its from da rack den ur looking a easy 80 plus i presume from wreckers if u noe wat ur doing not hard job disconect the rack from the front rotors unblth thebolts holding it up disconnect from the steering column its out
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    Flush it out and put some of the Penrite ATF 3 in it. Has some seal conditioners, cleaners, see how it goes that way first. Tighten the hoses as well and degrease to see exactly where the leak is coming from. Are you talking about on the rack of pump ? Weeping is normal on the rack, wet spots, and like i said, try the Penrite and see how you go. Main thing is to monitor level from resevoir.
  1. Vn Oil Leak :(
    By VNPOWER in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-09-2008, 09:27 AM
  2. Oil Leak
    By eagle13 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-11-2007, 09:19 PM
  3. Oil Leak
    By DND in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-11-2007, 07:30 PM
  4. Oil Leak
    By VRsharkie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-10-2007, 06:23 PM
  5. Vn Leak!!!! Help
    By spacattack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-02-2007, 08:05 AM
