Results 1 to 5 of 5
Thread: Dead Engine V6 overheated.
    Aug 2008
    Default Dead Engine V6 overheated.
    Hi
    Need some advice please. My engine overheated last night due to someone (not me) not putting the radiator cap back on properly which i didn't know about until too late. It heated up and then temp went down so i thought it was ok. Then it developed a knock and the engine stopped. Pity the temp reading wasn't accurate because it measures the water temp (when there is no water in it the reading stayed low, i guess it was measuring air temp). anyways so now the engine wont turn over. What should i do? An engine with 3 months warranty is $550. What do you think is wrong with it? The engine turns but wont fire. Top end i guess stuffed. I want to sell this car as well so i just want to get it running.
    Thanks for any replies.
    John
    1998 VT Acclaim S1
    Feb 2008
    Everything will have been wrong with it...piston rings, cam, valves etc etc etc. Basically, a cooked engine is stuffed.
    Personally, its your car so you should have been looking after it with regular maintenance, which can be as simple as taking 30 seconds to pop open the bonnet and running your eye over the engine bay to spot if theres anything missing or wrong. So it doesn't matter who's fault it is for not putting radiator cap on, the blame still lies on the driver or operator of the vehicle at the end. But we all learn from experience, some more expensive than others
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Ecotecs warp pistons when they overheat so you won't have compression, thats why it won't start. I wouldn't bother trying to fix it, you may be very lucky that it only did a gasket, but I doubt it. It would cost you more that $550 to repair yours.
    Visit my Facebook page
    vt calais supercharger
    Oct 2008
    My VT Supercharged Calais did the same thing. A hose blew and I only realised that the engine had overheated when I heard a clanging noise coming from the engine. I quickly pulled over and had the car towed to a garage. They replaced the hose and motor seems OK. I was just wondering what damage this overheating could have caused to the motor. Will there be a loss of power or any other future problems that result from this. The mechanic did not think so but I am not too sure.
    Any comments from anyone who had struck a similar problem. Thanks.
    VP Executive R-spec
    Jan 2005
    This almost happend to me once :S I had the cap on crooked after being in a rush to get the car ready for the drags, someone picked it up at the inspection tent once I got to the track, luckily it had only just warmed up by the time I got there (about 20 ks) so hadn't lost much/any water yet. I would have seen the temp spike after a race or two anyway but still. I've had blown hoses before and you can spot them pretty quick
  1. Battery dead again! Check Engine Warning!
    By joshtaylor87 in forum VE Holden Commodore (2006 - ?)
    Last Post: 14-08-2008, 07:55 PM
  2. overheated
    By boReys in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-02-2008, 09:36 PM
  3. Are V6 Buick engines throw away items once overheated?..
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-02-2006, 09:30 PM
  4. VN Calais not starting -exhaust overheated!
    By northmelb2001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-11-2005, 10:04 AM
  5. overheated fuel pump maybe? 95 Vs
    By BergR1 in forum Electrical Wiring / Questions
    Last Post: 14-04-2005, 08:57 PM
