Results 1 to 2 of 2
Thread: Traction contol light question for the advanced!
    keza87's Avatar
    keza87 is offline JCCC NSW Member
    VX Wagon S3.8 M5
    May 2006
    Default Traction contol light question for the advanced!
    Hi,
    This may be a question only a technician could answer with a Tech2.
    My car is fitted with traction control and I have had the cluster changed to a VT HSV 3 window item. The only issue is that the VT HSV cluster does not have the cut outs for the traction control lights.
    I have tried wiring a new separate light for the TRAC OFF but have since discovered that it doesn't work with the VT HSV cluster but if I install the old cluster the light I have made works.
    Is this because the Holden dealer has not enabled the light within the cluster?
    I have tried finding the wire that goes into the back of the cluster but believe that there is no wire and the cluster receives the TRAC OFF info through the ABS serial data. Looking at the wiring diagrams the Low TRAC light is straight from the ABS module but not the TRAC OFF light.
    Can someone please inform me if I am correct or that the VT HSV cluster does not support the traction control lights.
    Thank you for your help in advance.
    JCCC NSW Member
    Check out my ride here : VX Manual Wagon with VZ Senator front end now Supercharged
    Just Commodores NSW Chapter. Join in for a cruise some time!
    Click here for more info
    WAGON MAN's Avatar
    WAGON MAN is offline Gas Sleeper
    VX S2 Berlina Wagon with Phreddied bits.
    Jun 2006
    North Coast , NSW
    Ask Doctor Bob here.
    I'm sure he will know.
    I like my roo well done
  1. Question Re Traction Control 5.7 V8
    By holden#1 in forum General
    Last Post: 06-12-2009, 08:28 AM
  2. Engine warning light and traction control off?
    By Jom in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-08-2008, 04:09 PM
  3. WTB VS ute elect window contol
    By brewster123 in forum Swap / Wanted to Buy / Trade
    Last Post: 07-02-2007, 11:54 PM
  4. Traction Control Light Not Showing.
    By VTSSDUDE in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-01-2006, 11:21 PM
  5. 'Low Traction' light & high rev noises...
    By Randy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-02-2005, 07:46 PM
