Hi Guys
At the moment, my Oil Light on my dash (believe thats what its called), keeps flicking on and off with this annoying beeping sound. Usually last around 2 - 3 seconds. It is giving me the sh*ts big time.
I would really appreciate your help as i have no clue as to why this is happening
- Oil is also full
cheers
Sounds as if your oil pressure switch (next to the filter) is cactus!
how much will one of those set me back?
and also how do i determine if this is infact the problem
Check your contacts to the oil pressure switch is clean first. Check the connection is good too and the wire is not broken or damaged. If the problem is still there, then you'll probably need a new oil pressure switch. It shouldn't cost much.
