| VT - VX Holden Commodore (1997 - 2002) Talk about anything relating to the VT - VX Holden Commodore. |
10-09-2008, 07:53 PM
Ride: VT Executive Series 2
VX foglights on VT
Whats the procedure, or can it work to get vx foglights on a vt. i have the vx bodykit ready to install on my vt but wondering if foglights can work
10-09-2008, 08:01 PM
Ride: vx ss
2mor when its daylight like check if you have the wiring tucked in under your radiator or beind your dash i had it in my old vx lumina.
ill check 2mor what colour the plug is and take a pic behind my dash face so you can see if you have it.
10-09-2008, 08:54 PM
im not sure,if the wiring is there will i have to install the fog light button? That would be great if you could be able to tell me if the wiring is there, thanks for yur help lumina.
10-09-2008, 09:24 PM
Donating Member
Ride: WH II Caprice, 5.7
Quote:
Pretty sure your wiring will be there. You will need the proper switch which should plug into the connector which is behind the headlight switch but you might need to search for it. As lumina01 said, the plugs for the lamps will be behind the bumper, either side of the radiator. You can see them from under the car.
10-09-2008, 09:28 PM
beautiful, just what i was after. thanks a heap, will i have to cut a hole for the fog light switch? or would it be worth buying a whole new dash with the hole there?
10-09-2008, 09:43 PM
Ride: vx ss
you can cut if you want, easyier to buy a new dash face with a hole already there
11-09-2008, 07:48 AM
Ride: VX 'S' S1
you will also need to buy the relay and fuse for the fuse box under the bonnet on the drivers side
__________________
If you can't be a good example -- then you'll just have to be a horrible warning.
25-10-2008, 09:55 PM
haydz - Queer as Folk!
Ride: 98' S1 VT Exec - Pov Pack
Quote:
So basically if the wiring is already under the front bumper it means I should also have the connector in the dash?
And all I would need is just put a fuse and plug in a relay to get them crankin'?
26-10-2008, 08:04 AM
Donating Member
That's right, but you will also need a switch.
26-10-2008, 08:55 AM
Quote:
Yeah I've already got the factory foglight switch.... Is that what you mean?
26-10-2008, 05:42 PM
Donating Member
Yes, that's the one I mean. It should be very easy to set up.
26-10-2008, 09:31 PM
all done! hardest part was carefully cutting a spot the foglight switch.... Pic's will be in my thread in a sec!
Cheers for the prompt replies bud!
30-10-2008, 11:53 PM
Ride: VT Executive
hey hows it going?
just a question, i want to hook up my fog lights the same as you have. What do you mean when you say plug in a relay? sorry if im a little slow. the fuse bit i get, but you plug the foggies in, hook up the switch, put a fuse in and then what??
cheers
31-10-2008, 06:09 AM
fuse is already there - but just above your battery there is another fuse box which houses your major relays - hope these pics help!
Relays are about $3 or something like that from MOST good auto retailers - I got mine from my local Holden joint.
