Results 1 to 15 of 15
Thread: missing when warm vt v8
    vt v8 bt1
    Sep 2008
    Default missing when warm vt v8
    hi got a problem with a vt v8 missing when warm, i have changed alot of parts new coil new leads plugs injectors new fuel pump and still missing
    i have noticed the dash rev tacho is moving around a bit more than normal
    any help would be appercitated
    vt v8 bt1
    Sep 2008
    nicko's Avatar
    nicko is offline Carbon Positive - DO IT!!
    75 cruiser ute
    Sep 2007
    sa
    nicko's Avatar
    75 cruiser ute
    Sep 2007
    sa
    have you logged any fault codes?
    no longer a hoon by association - the commodore is gone
    vt v8 bt1
    Sep 2008
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    might be a coil dying. it will be the electrical side of things by the sounds of it.
    Reaper
    adam69 is offline Banned
    VT Clubby
    Oct 2004
    Mine did that also,if you have done the coil try and borrow another ignition module and see what happens.Mine was runnind very bad so we swapped the module and it was betterbut replacing the coil fixed it for good.
    vt v8 bt1
    Sep 2008
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    check ur leads arent crossing eachother or shorting on the engine somewhere,
    also make sure your leads are ALL plugged in correctly on both ends
    vt v8 bt1
    Sep 2008
    Default vt v8 no luck
    all leads been checked, also tryed another ignition module off a mate still no luck, i thinking dissy ?? the hall sensor what does this do when it plays up ??
    vt v8 bt1
    Sep 2008
    Default dissy
    any one had problems with there dizzy ?? took the car to ultra tune put on tech 2 and no code
    Ozzie's Avatar
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    Not sure if the VT 5L is effected by this, but VN-VS 5Ls are prone to the erratic idle thing. Mine seemed to fix after i re earthed the alternator. Can get pics of what i mean if you want (to see if the VT is the saem as my VP)
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    STEALTHY™'s Avatar
    Jan 2005
    Quote Originally Posted by xcopvrbt1 View Post
    Don't take it back to any franchise store if you want to keep your money. Find a decent mechanic.
    cheers sexy
  15. #15
    vt v8 bt1
    Sep 2008
    Default car fixed
    finally some good news, car is fixed
    took the car to get dyno tuned today at electronic automovtie in epping
    on the dyno it was running very lean due to a faulty air flow meter
    tryed a new one on the dyno and car is back to 100%
    thanks everyone for your help
    i hope this will help some one solve there problem
  1. best way to warm up your car...
    By adamc11 in forum General
    Last Post: 22-10-2008, 07:32 AM
  2. Missing at idle (when warm?)
    By M-Leach in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-07-2008, 10:13 PM
  3. Warm Air VR
    By not_just_any_vr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-07-2006, 09:32 PM
  4. Warm Air
    By Stretcher Bearer in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-02-2006, 10:16 PM
  5. Need help with car when warm!!!
    By Sick Blue VL in forum VL Holden Commodore (1986 - 1988)
    Last Post: 14-11-2005, 09:34 PM
