Hi. ive just purchased a commodre vt series 2 executive.
I'm just trying to make sense and get info fro some of the codes.
If anyone can help than thats great. Codes below
Paint 2734 also noted as G082
Engine LN3
Trans M30
A/c C60
main ones im looking for are these option codes:
CRS ?
AL6 ?
Trying to work out also if it has ABS. I don't hink it does as no warining light comes on when ignition is first turned
If you look in the engine bay on the driver's side near the fuse box you will see a squarish module with about six tubes coming out of it, if you have ABS.
MY RIDE
Easiest way, Fly down a bumpy road, Hit the brakes, And if your foot gets a massage, You have ABS.
I personally don't like the feel of ABS.
Originally Posted by Yoda
thanks for the replys
c60 is Front Manual Control Air/Con.
A** is usually an Interior option, I dont have it on my sheet, I have an SS.
e.g a31 Power Operated Side Widows Front and Rear
ah6 Power adjust drivers seat.
Paint codes can be taken to any body shop to get a name for the colour off the code.
Engine LN3 6? I don t have these codes.
Transmission M30 Manual, Non Getrag 5spd?? Again dont have these codes.
CRS ??? Dont know,??? CRS factory, body?? as above C is Air/con but CRS unknown.
AL6 is cargo restraint, CRS does not come up in the list on my Holden Program
I get a code of V9R which should be 'Merchandised package Pontiac G8 GXP'
What is in the package, and is this a legit code?
GM Holden Colour Codes your colour is tundra pearl gray with yellow and pink tint metalic
you have abs standard from VS.
their should be a logo on the "B" pillar SRS.
Research has shown that men usually sleep on the right side of the bed.
Even in our sleep we happen to be right.
Powered By Garrett
