Results 1 to 9 of 9
Thread: Wagon rear doors same as sedan?
    Factory Blown VY S2 Calais
    Jun 2005
    Brisbane Bayside
    Default Wagon rear doors same as sedan?
    Looking for door trims - are wagon rears the same as sedan?
    Also - do vy/vz fit vt/vx?
    Thanks.
    VX 'S' S1
    Apr 2005
    South East,Victoria
    All wagon rear doors have a different window frame to the sedans.
    VT/VZ doors are interchangable ,
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by Fletch_QLD View Post
    Thanks.
    Even though the top part of the rear doors are different in the wagon, the door trims are the same.
    MY RIDE
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    Follow on from that, the metal is the exact shape. So its possible (depending on how much effort you want to put into it) to, for example, replace a damaged sedan door, with a wagon door, using the sedans frame.
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    Jun 2005
    Brisbane Bayside
    Soo confusing - sounds like wagon door trims are maybe/yes/possible for sedan rear doors ...
    STEALTHY™'s Avatar
    Jan 2005
    Not confusing at all. The metal is the same, meaning the door trim is the same. My door trims aren't higher than my window line.
    cheers sexy
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Quote Originally Posted by STEALTHY™ View Post
    You could do it if you were game enough. First you would have to remove the old ones which would be a big job in itself.they are spot welded and mig welded , so you would have to drill and grind them out .If they are like the VB/VL doors they have 12 spot welds and 4 mig welds . they you would have to be spot on welding the new ones in as they are held together in a jig before welding .
    Jun 2005
    Brisbane Bayside
    Thanx mate - good to go then
    cheers
    STEALTHY™'s Avatar
    Jan 2005
    Quote Originally Posted by Dayvo View Post
    As i said, depends how much effort you want to put in. Possible nonetheless
    cheers sexy
  1. vl wagon or sedan 2 doors
    By walesy in forum Projects
    Last Post: 25-12-2009, 10:31 AM
  2. rear bumper,sedan and wagon
    By qik42c in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-09-2008, 06:42 PM
  3. Do VT/VX rear sedan springs fit a VT Wagon?
    By muso in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-07-2006, 09:09 PM
  4. Are VN wagon rear doors the same as the sedan?
    By andy05 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-06-2006, 03:43 PM
  5. VK or VL Sedan Doors on a VH Wagon?
    By NVS in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 21-06-2006, 04:05 PM
