Results 1 to 4 of 4
Thread: Rear seal oil leak
    VT SS
    Sep 2008
    Default Rear seal oil leak
    New to all this: so i got a lot of oil leaking from the rear seal can anyone tell me how to go about fixing this.
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    Either use a High Mileage oil like Shell Helix pLus 15W50 HMV or Valvoline Maxlife 20W50 for at least 2 oil changes, see if it slows it. These have slightly higher levels of seal swell over normal oils. Otherwise get some Auto-RX which is a seal cleaner, if the seal isn't damaged it will clean both sides of the seal making it seat properly.
    MY10 SSV UTE
    Dec 2006
    Melb
    Default ...
    or do the rear main seal and other goodies while its out?
    think engine has to come out on 5l's?
    1970 AMC javelin, S2 stagea
    Jun 2008
    5L is engine out as the crank has to be taken out to fit the seal, may be the distributer seal and oil running down.
  1. Ecotec rear main seal leak
    By Sara Pax in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-11-2011, 02:07 PM
  2. Rear seal oil leak
    By SDGVT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-09-2008, 12:25 AM
  3. F&*^ Rear main seal leak
    By CALAIS 6 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-02-2007, 11:55 PM
  4. possible rear main seal leak. is that a good excuse for a manual conversion ?
    By evil_monkey in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-08-2006, 10:11 PM
  5. Oil Seal Leak Help
    By VL-VP-VT in forum VL Holden Commodore (1986 - 1988)
    Last Post: 13-07-2005, 08:40 PM
