Results 1 to 5 of 5
Thread: air/vac leak causing rough idle?
    VT Executive
    May 2008
    Alexandra,Central Otago NZ
    Default air/vac leak causing rough idle?
    My VT is suffering a rough idle especially when in drive sitting at the lights, its almost like an intermitant miss. Ive got it on direct injected gas 90% of the time & have replaced everything ignition wise (leads, plugs, coil packs & ignitor) I had it mentioned that gas is hard on seals, hense thinking it might be the problem? Any ideas anyone?
    vs commodore sedan
    Jul 2005
    mine was doing the same though not on gas thought it was the intake started to break it down and found all it was is just a old breather broke but was still sitting there looking like nothing was wrong
    VT Executive
    May 2008
    It does it both petrol & gas. Where is the breather you had the problem with?
    1970 AMC javelin, S2 stagea
    Jun 2008
    VT Executive
    May 2008
    Hey thanks for that! I will check it when I get it back, its getting a full repaint at the mo
  1. 400rpm Idle... causing fuel consumption probs?
    By dawg in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-05-2008, 06:55 PM
  2. Rough Idle and Random PS Leak?!
    By knagggs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-03-2007, 02:29 PM
  3. Rough idle when hot
    By Motorsport in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2005, 01:31 PM
  4. Rough Idle!!!
    By boojak87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-05-2005, 01:43 PM
  5. VR V8 Rough Idle
    By HOTVR5L in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-04-2005, 12:35 PM
