Results 1 to 4 of 4
Thread: Engine light on with no revs, then back to life!
    VT Berlina S2
    Dec 2004
    Default Engine light on with no revs, then back to life!
    Hey All,
    This morning im on the motorway doing 100 with cruise control on as well as air con (telling you in case it matters).
    The engine felt like it stalled, but didnt go into 'reds'. Only the Orange engine light went on and the taco needle dropped to zero, then about 3-4 seconds later it came back to life by itself and i continued driving.
    Any thougts?
    1998 VT Acclaim S1
    Feb 2008
    See if the problem occurs again in the near future. Its either a slightly loose connection at your PCM-BCM-console terminals or your computer just decide to suprise you with a spat.
    VT Berlina S2
    Dec 2004
    Thanks ill try that.
    I have been having starting problems lately as well. Codes 46 to 49, CAS related.
    I changed the CAS a few months ago and my car wouldn't start, so i put the old one back in and it was fine after that.
    Now it just stalls every now and then at the lights.
    I also noticed that leads 3 and 5 are thinner than the rest. I just bought a set of 8mm leads so ill try that and hopefully the things behaves
    Cheers,
    Eddie
    VT Berlina S2
    Dec 2004
    Ok. I just finished changing the leads. Went for a drive and i guess they are all where they shoud be.
    One thing i noticed though was when i pulled the lead off plug 6 there wasengine oil surrounding the metal casing. I checked the plug and it was tight, so i might have a leak from somewhere above it??
  1. bring a VB back to life
    By shanhsv in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-04-2007, 11:08 PM
  2. Bringing the calais back to life
    By kingj133 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 27-09-2006, 10:57 PM
  3. Holden's Wild Hot Rod Brings FJ Back to Life
    By Darren in forum News/Updates
    Last Post: 31-10-2005, 10:40 AM
  4. Tacho DiEd & CaMe BaCk 2 LiFE!
    By StealthX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-05-2005, 11:20 PM
