Hey everyone, i have a vt s1 ecotec and a few weeks ago i got all the bushes and camber kit replaced at pedders (expensive operation), one problem, since then traction control and abs wont workanyones help would be great before i start pulling wheels off n stuff. cheers
They may have disconnected your sensors and forgot to plug them back in or perhaps even damaged one.
Did this happen immediately after you had the work done or after a while?
MY RIDE
they noticed it not working after they finished the car, so i reckon you could be right about sensors, where are they located and do i have to pull wheels off?
sounds like the abs module is stuffed
cheers GM
d4efintly abs module my old vt aclaim module blew...through holden was gunna cost 1000 bucks parts and labour got second hand one fited and parts and labour cost me 400 bucks through brother in law its not to hard to change from what he told me
*LaUgH nOw CrY lAtEr*
$400 for a second hand module and fitted is pretty steep considering a new unit only costs about $500 and it takes about half an hour to remove and fit the new one on....
When all the lights come on and stay on its due to a bad earth inside the ABS ecu, can check this by wriggling the main harness on the side of the module and see if the lights go out.
If you find this to be the problem, only buy the ecu part as you won't need the part where all the pipes go and there is a special procedure to bleed that part of the module.
cheers guys, im gona have a look underneath this weekend to see if they didnt connect the sensors back up fingers crossed thats all it is or im up for a few hungee
