Hi just looking over a friend's VT Calais cooling system. When do the thermos kick in? I switched the air con on and the right hand side fan kicked in (ie: the one blowing on the air conditioning compressor). Do they operate independently? My EL falcon, they kick in and stop at the same time. So will the left one also kick in when it reaches a certain temp? or is it faulty? If it is faulty, where's the best place to start?
thanks!
I've been looking through some threads and see that just the passenger side fan kicks in when air con is on. and they will both kick in at 104 degrees? is this correct. Is there a way to bring up exact coolant temperature? My falcon has a diagnostic mode on the cluster. Does the VT have something like this?
