Results 1 to 20 of 20
Thread: VX Supercharging
    the_ozz_man's Avatar
    the_ozz_man is offline Ozzy Ozzy Ozzy
    VX Equipe Series II
    Apr 2008
    Sydney Australia
    Default VX Supercharging
    G'Day Guys,
    I am planing on Getting my VX (3.8LV6) Supercharged soon
    Just wondering how much more Petrol i will use?
    Will it be a little more, a lot more or will i start getting christmas cards from my local BP
    Cheers,
    nicko's Avatar
    nicko is offline Carbon Positive - DO IT!!
    75 cruiser ute
    Sep 2007
    sa
    yeh it will use more petrol. add another 3-4L per 100kays. Even more maybe because if you charge it then you will be booting it alot more
    no longer a hoon by association - the commodore is gone
    VX Equipe Series II
    Apr 2008
    Sydney Australia
    Jun 2005
    Quote Originally Posted by nicko View Post
    i doubt it will increase that much
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    VT Acclaim
    Sep 2007
    Been tempted to do something similar. How much does it usually cost to purchase a supercharger with installation?
    Also heard that turbos a slightly better than supers for fuel. Not sure how true that is.
    nicko's Avatar
    75 cruiser ute
    Sep 2007
    sa
    to charge your car, put away $6000.
    To turbo it will cost more.
    Turbo is dont think would be as good on fuel as a charger
    Jun 2005
    wrong again. get a l67 engine for $2000 maybe and throw that in. done. supercharged
    turbos are better on fuel. superchargers require engine power to spin the charger. turbos use exhaust gasses making them more efficient
    nicko's Avatar
    75 cruiser ute
    Sep 2007
    sa
    Quote Originally Posted by stocky View Post
    Because thats cheap
    Jun 2005
    Because thats cheap
    cheaper than the 6000 you quoted
    nicko's Avatar
    75 cruiser ute
    Sep 2007
    sa
    indead, but i was refering to his question about supercharging his current motor
    Jun 2005
    and i was refering to your comment about requiring 6000 to supercharge his car
    VX Equipe Series II
    Apr 2008
    Sydney Australia
    Jun 2005
    Quote Originally Posted by the_ozz_man View Post
    Thanks Guys
    The CAPA Kists look pretty good
    id pick the l67 any day over those. less hassles, and legal
    VX Equipe Series II
    Apr 2008
    Sydney Australia
    Where in Sydney can i get the Supercharging done!!
    all the websites i can find are in other states
  15. #15
    vx_ss_black's Avatar
    vx_ss_black is offline phantom vx
    vx ss
    Aug 2008
    campbelltown
    i think supers are better on the fuel in the same rev range before the turbo cuts in. you got turbo lag before then which means you need to accelerate harder to get the same performance as without a turbo. with a supercharger the power is already there from idle so you wont need to accelerate as hard. either way is going to use more fuel, but i reckon the turbo will use more as a daily being used in the low rev range as a result of turbo lag. thats my thoughts now everyone crap all over my thoery.
  16. #16
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    So the CAPA Kit, Raptor Super Charger, and Yella Terra Kit for the V6's are not legal ? I have a feeling the YT kit is street legal. The other 2, its the way it may be plumbed or something like this, how its vented etc. Also the change to the cone filter makes it illegal, but CAPA i think do a custom box for it to cover it, making it legal again.
  17. #17
    radarak47's Avatar
    radarak47 is offline I lean to the right
    VXII Acclaim
    Jun 2008
    Sydney NSW
    In a nut shell if you run the Raptor kit in NSW.
    First you need an emmisions test which should be fine. as the ECU remains (original casing at the very least). The Equivelent of a BOV (Bosch CBV) is plumbed back so no blead off to atmospheric. As long as your CATS are ok and your EGR valve is still setup to blead exhaust gasses back into the plenum you should have no issues with the readings which are CO not CO2.
    Next Engineers certificate. The kit again is sturdy and should pass the requirements. Remember an Engineer will also check the decibel reading from the exhaust, in NSW this is 2/3 the max RPM no louder than 90db for the VX Commodores so ~4000rpm. They will also check wheels/tyres and the max diameter/width allowed on your vehicle.
    If you check out the do's and don'ts prior to getting the tests you should be ok. Another rule of thumb is you always look better in the eyes of the RTA etc if the car is still registered (pink slip only required) as a lot of things will be overlooked than if you need to go a full Blue slip.
  18. #18
    Jun 2005
    Quote Originally Posted by vxcalais_01 View Post
    they might be engineered, but wont be EPA friendly. l67 is the only one where you wont have these troubles. YT kit is a ripoff for pretty much the same thing as a stock l67, without all the good engine internals. much cheaper to find a l67 engine
    is the emissions test done by the EPA? they have a checklist when testing the car, it has supercharger, turbo, intercooler on it. they can also check the memcal inside the ECU. when i went for an EPA test, even with a stock motor, they knew that my memcal has a socket soldered onto it and that it was running a modified tune.
  19. #19
    radarak47's Avatar
    VXII Acclaim
    Jun 2008
    Sydney NSW
    Yeah the emissions test is done by the EPA. I was informed the issue is not if it has a modified tune, the issue with the EPA is if it can be changed on the fly, i.e. if the tune can be changed while you are in the car and driving. That is why all aftermarket programmable ECU's are not EPA friendly. They still test to make sure your pollution readings out of the exhaust are within legal bounds.
    Stocky when they knew you had a modified tune did they fail you? If so did they tell you what exactly they failed you on?
  20. #20
    Jun 2005
    failed due to a slight misfire and non factory tune
  1. Supercharging VR.
    By tysons_2001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-08-2009, 08:37 PM
  2. Supercharging V6 3.8L VS???
    By ruredi in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-01-2009, 06:02 PM
  3. Supercharging on LPG
    By DavoVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-08-2008, 09:03 PM
  4. Supercharging my vc..
    By Shifty1 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 24-06-2006, 03:20 AM
  5. Supercharging My 8
    By EX_FORD_BOY in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-04-2004, 04:47 PM
