Results 1 to 16 of 16
Thread: WH Statesman clock wires ?
    Factory Blown VY S2 Calais
    Jun 2005
    Brisbane Bayside
    Default WH Statesman clock wires ?
    So red and black are easy to figure out, but can anyone tell me what yellow and green are for? Obviously one goes to 'lights on' - but I can't think what the last wire would be?
    cheers
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    It might be a constant power wire, to keep the time when the ignition is off.
    MY RIDE
    Jun 2005
    Brisbane Bayside
    Quote Originally Posted by accentstencil View Post
    I was assuming red would be constant power - and that it would tick over even with the ignition off ?
    Jun 2005
    Brisbane Bayside
    Solved my own problem - soo easily.
    Circuit board of the clock tells the story.
    red B+ (battery positive)
    black GND (battery earth)
    green ill- (lights earth)
    yellow ill+ (lights positive)
    Too easy. But can I hook ill- to GND ? I don't get why they need to earth seperately?
    cheers.
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Here is a diagram. I am not too good at working them out but maybe you are. It is easier to read if you open the link in a new window.
    Attached Thumbnails Attached Thumbnails WH Statesman clock wires ?-wh-wiring-diagram.jpg
    MY RIDE
    Jun 2005
    Brisbane Bayside
    VX Calais V6 Supercharged
    Sep 2007
    how did you go with this?
    im about to put a statesman clock into our vx calais.
    im tempted to connect both grounds to each other. im thinking ground is ground no matter where it comes from.
    HSV +6
    Mar 2006
    Mornington Peninsula
    Same here, advice appreciated. Also i was told easy to wire it upto the Hazard light wires, is that how you have done it?
    Jun 2005
    Brisbane Bayside
    I am very happy with mine. I installed it at the same time as putting blue LEDs in the climate control and new stereo install - so wiring it in was easy - I used battery +/- and 'lights on' straight from the stereo loom.
    VT Calais 5lt
    Sep 2006
    Jun 2005
    Brisbane Bayside
    Yeh - easier, and prolly a better result over all, but more expensive. The main thing for me was the clocks are easier to get a hold of than the whole fascia.
    GAMBLR's Avatar
    GAMBLR is offline More trouble than u think
    '04 VZ Calais LS1
    Dec 2006
    Whyalla (yawn), South Australia
    Ahahaha... I just noticed the song on the head unit... Quite befitting of the thread
    CruznCalais
    [GAMBLR]
    The VZ is here! About time!
    Jun 2005
    Brisbane Bayside
    lol
    Quote Originally Posted by CruznCalais View Post
    2002 VX II Acclaim
    Aug 2008
    I just bought a WH statesman fascia with all mode switch/clock/headlight/fog light switchs for $101, Cant wait to install it all!
  15. #15
    VT Commodore Berlina Wagon
    Mar 2010
    Default WH Clock wiring
    Looking at the wiring diagram it is easy to see why it has a separate earth. Remember, you can dim the dash lights!! Therefore the yellow picks up the +ve from the park light circuit and the green negative from the adjustable ground point supplied by the Body control module. If you tie the green to chassis ground it will work, but your clock backlight will not dim with the rest of the dash lights.
    Regards
    lpme126
  16. #16
    vt ss commodore series 2
    Sep 2009
    Geelong, Aus
    This is a good idea. I recently replaced the head unit in my vt ss and subsequently lost the clock function. So I thought I'd get the statesman facia which has the clock built in. Woo hoo I thought. Smart thinking. Well until I found out I couldn't put it in cuz I haven't got climate control. Now seeing this setup with the statesman clock in a normal facia i'm gonna do this mod instead. Does the clock sit flush with the dash?
  1. WTB - wh statesman dash clock
    By lumina01 in forum Swap / Wanted to Buy / Trade
    Last Post: 03-02-2008, 12:01 AM
  2. VQ Statesman Roof Clock
    By mulligan-can in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-04-2007, 09:42 PM
  3. clock
    By ab56452001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-02-2006, 10:19 PM
  4. Clock
    By VLishes in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-01-2006, 11:35 PM
  5. turn clock back. vr statesman
    By gold statesman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-07-2005, 06:32 PM
