Results 1 to 2 of 2
Thread: VT supercharger pulley movement...
    mcgyvah is offline try it & see
    stock Supercharged VT S series I
    Jan 2007
    Default VT supercharger pulley movement...
    So, I had a bit of a pulley squeak and removed the charger belt to spin the pulleys and see which one was the culprit.
    In the process I gave a turn on the snout pulley and it moved left to right about 10mm and seemed to catch internally. It felt like it was turning on the shaft? lt seems a little strange.
    I would think I shouldn't be able to move it at all. or that I would feel the scroll moving internally?
    Anyone else noted this or willing to remove the belt and see if theirs does the same?
    Assuming I do have an issue.... it would be a good opportunity to upgrade to a new snout and larger pulley. I have noted a few different kits out there. Is their one that the pulley size is easily interchanged without puller tool?
    signature
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    I would say a bearing has collapsed in you supercharger snout so things are binding up and causing your belt to slip and causing the noise you can hear. I think Yella Terra does a snout replacement kit where you can just bolt on different size pulleys.
  1. supercharger pulley
    By harro_VR in forum General
    Last Post: 23-10-2007, 03:19 PM
  2. WTB Supercharger Snout and Pulley
    By VTSick in forum Swap / Wanted to Buy / Trade
    Last Post: 03-01-2007, 01:48 PM
  3. Supercharger Pulley Problems
    By VTSick in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-01-2007, 10:42 PM
  4. Transmission movement
    By Sebastian in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-03-2006, 11:51 PM
  5. CRS Supercharger small pulley belt
    By commodore in forum V6 Development And Modification
    Last Post: 27-01-2006, 09:41 AM
