Results 1 to 4 of 4
Thread: vt 1997 mdl - need to weld.
    vt
    Oct 2008
    Default vt 1997 mdl - need to weld.
    hey people
    ive gotta weld a few small things on my 1997 mdl vt berlina, just wondering what do i have to disconnect to make sure i dont fry anything ? just the battery ?
    thanks
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    What do you need weld?
    and what type of welder are you using. I surely hope your not planning on using an arc, but it seems that way if you need to disconnect the battery.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    vt
    Oct 2008
    will be using mig welder.
    im guessing no matter what i should disconnect the battery ?
    i just have to weld a small brace in the boot which is actually spot welded on but im just drilling the spot welds off the old one and just plug welding the new one on.
    and i also have to weld the front drivers door middle hinge, it looks like it just located the door or somthing ? well the little mount on the chassis is half cracked. just needs a bit of a clean up and welding..
    anyone know if anything can just get fryed from welding any part of the car ?
    cheers
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    you should be safe.
    alot of people have their exhausts and mounts welded whilst on the car
  1. weld vs spool????
    By anothervn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-04-2008, 08:32 PM
  2. Cold weld - Turbo oil line return!
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-01-2007, 04:40 PM
  3. 1997 Vn ???
    By Claudy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-01-2007, 08:59 PM
  4. modify my vs 1997
    By tobesvs in forum General Discussion
    Last Post: 20-07-2006, 08:01 PM
  5. weld or mini spool
    By manual vn wagon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-07-2005, 05:21 PM
