Results 1 to 2 of 2
Thread: Possible leak in the inlet manifold
    VZ Exec Wagon
    Jun 2005
    Perth, WA
    Default Possible leak in the inlet manifold
    Hey guys having some problems with the dunnydore, its got ever such a slight rough idle, when on petrol (even worse on gas) I used to get hesitation only on gas before but its starting to become apparent on petrol now aswell, just had the fault codes checked by holden, and in the history were left & right O2 sensors high voltage so im assuming they are no longer faulty? Im leaning towards the idea of a leak somewhere in the inlet system, what are the usual suspects on a vx v6? As for the hesitation how likely is it to be the throttle position sensor? I also get a constant feeling of 'misfiring' in between 80-100km/h although having put the car on an oscilloscope i can conclude it is not an elctrical mis-fire. The car has new plugs gapped to 1.0mm (this is optimal for lpg) new quality champion leads, and 3 new coil packs, the people that fitted the gas have also fitted 6 new gas injectors.
    Sorry it is abit of a long winded one, basically all the problems im having first started on lpg but have now migrated to petrol.
    VZ Wagon (dual fuel)
    Lowered on lovells springs
    VE SSV rims
    2 1/2 stainless exhaust with DD exit
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    Quote Originally Posted by neobristol View Post
    Firstly, 1mm is not optimal, its just too small. 1.3mm is the smallest you should go. If 1.5mm works without backfires, stay with 1.5mm. You now have a more consistent weaker spark instead of a longer stronger spark. Secondly, Champion do not make quality leads. The only good plugs they have which are some of the best are Champion Gold. Do not go a colder plug as standard plug is cold enough.
    Recheck leads, plugs etc. Regap them to 1.3 at least. Alot of leads start playing up out of the box. LPG is more reliant on spark strength/quality thats why it is worse on gas.
    When my inlet manifold gasket went, i found oil in the radiator.
  1. inlet manifold gasket leak?
    By Apoc in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-06-2008, 09:50 PM
  2. l67 inlet manifold
    By Adrian in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-06-2008, 12:46 PM
  3. vs inlet manifold
    By jas98 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-02-2008, 12:49 AM
  4. inlet manifold
    By ab56452001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-01-2007, 09:52 PM
  5. Inlet manifold-exhaust manifold cracked
    By aussieghostrider in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-06-2006, 10:23 PM
