Results 1 to 14 of 14
Thread: VT Commodore or EL Fairmont?
    VY II Berlina wagon V6
    Jan 2005
    QLD
    Default VT Commodore or EL Fairmont?
    Gday all,
    Looking to buy another car for work but having a bit of a hard time deciding. I have found these 2 cars:
    1997 VT Commodore wagon Exec
    160,000kms
    Green/Blue colour
    Full history
    Maybe 70% tyres (RE92's)
    Interior a bit of wear and tear but exterior immaculate
    A/C cool not cold
    Dark tint
    $4,100
    1997 EL Fairmont wagon
    201,000kms
    Navy blue
    Part service history
    90% tyres (Michelin energy xm1)
    Interior immaculate, but few scratches and stone chips on bonnets
    A/c would freeze ur tits off
    On gas
    Redback 2.5 inch mandrel bend exhaust
    $3800
    Both cars appear to be mechanically sound no leaks etc. Gearboxs are comparable I guess. They both drive pretty well.
    I am neither a Ford or Holden man, but I do like the look of Commo wagon better! But ill be doing a s'load of towing!
    Which would you guys choose? Have any of you moved from both sides of Ford or Holden camp?
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    KM's first would make me suggest the VT, Pretty low for it's age. With full serves history you can't go wrong.
    Plenty of room inside very comfy and a popular car with plenty of upgrades, handle good for a wagon has sedans IRS.
    On the Ford side, Towing would be best, More power and torque, Gas is a bonus but they do loose some go with gas, KM's aren't that bad.
    Big inside but for such a large car they have always to me felt like they shove you into the doors, Leaf spring rear set for heavy duty not ride quality.
    I'd be a bit 60/40 towards the VT, More because i have one, But they can tow it might just depend what you are towing that might seal the deal.
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
    Jan 2005
    QLD
    Well I do a ****load of towing, im a tradie and drive from GC to Brisbane daily. Its a big box trailer. Ford would be best for towing no doubt and cheaper to run. But Commodore wins looks contest hands down, and thats the prob! Its funny rear seat is more comfortable in Ford but front in Commodore seem better.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    You could gas it, But then that will cost you more, But it might last longer?, And as you said be more comfortable driving it..
    But if it's a very heavy load.. Though i was just behind a VY Exec towing a very large boat, Took me to pass it to notice it was a Commodore, The boat almost took 10% of the right lane with it.
    VTS5's Avatar
    VTS5 is offline TechJunkie
    '97 VT Spack 5 Speed
    Jul 2005
    Sth.East\Melb
    VT V8 Calais
    Mar 2007
    I have both a VT and a EF Ghia (similar to this monty)
    With no mods the falcon wins, sorry everyone but it is true. 200K is nothing on the straight six in will tow heaps better than a v6.
    They do drive quite well as the EL has the rear suspension sorted far better then the EF. For looks, lower and a nice set of wheels, all done.
    Parts are cheap and with the falcon on gas already, go for it
    50LTRv8
    adam69 is offline Banned
    VT Clubby
    Oct 2004
    Go the Ford,cheap to run,will tow what you want and because its a Fairmont it will have climate control,cruise,4x pwr windows too.
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    comming from expirance, the ef/el fall apart, the window regulators/mechinisms bend or break, climate control screw up, ecu's blow etc even with the basic cleaning, you might have a great engine but you need a body for it to move imo. vt quality is far superior to the el/f.
    i also dont get where people say the wagon fords are better cause there leaf sprung, yes leafs are good in weight situations if its set-up for that - the falcon is not, it only has like 2 or 3 leafs that are relatively thin compared to a commercial vehicle with 4-5-6 leafs. every ford wagon i see sag in the arse croic when towing a medium to large load. yes tyres will wear better when towing on one, my irs wagon dosnt sag as much as ive seen falcon wagon with similar loads.
    If you have poly-air bags fitted inside the springs which dosnt cost to much and you can eliminate sag on the commo. you cant fit bags to a falcon you will need to add extra leafs which make the ride alot harder when not towing
    just a few things to consider
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    vs calais
    Nov 2007
    vic
    VT V8 Calais
    Mar 2007
    I have not had half the issues mentioned with my mont.
    um, yeah right, bout the same from my experience.
    50LTRv8
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by 50LTRv8 View Post
    i know of a few vts in my family and friends and 3 ef's, 1 ef fairmont the sunroof and boot leaks like a sive, it has layers of contact over the roof and they have to put a tarp over it when it rains, when they bought it when it was 2 years old the climate didnt work, still dosnt, trip computer dosnt work, cruise dosnt work, power windows dont work, motors are either blown or the runner/guides/arms are bent also has contact over the top of one windows as the motor blew and window jammed. air bag warning has been on for a long time for no real fault, paint has faded and clear has peeled off, exterior panels dont line up, blown a head, drain batterys, has a slick knock in the engine and a couple of dead lifters, valve stem seal or two leaking. 250,000km on the clock and serviced well. if you see this car you couldnt sell it for 200 bucks
    2nd ef, blew an ecu, started burning a heap of oil, sheared the window winder handles off the regulators, common problem as they used plastic splines on the handle and metal splines on the regulator, strips them out. paint faded on this aswelll, they still like there falcons and traded it on a bf only got 2 thousand trade in for it
    3rd was a 97 ef/l futura wagon, 3 of the 4 window winder handle stripped, body rusting severley, ran like a dog, breaks shocking, for a 11 year old car the interior plastics had gone hard and brittle, i removed the triangle trim piece around the back door, when removing the door trim, snapped into 3 pieces when removing, and it wasnt cought on anything
    vt berlina never a drama, towed a large caravan, bought when 2 years old has now been replaced by a vz svz vt was passed down to grandparents, who know drive it around australia with a large caravan aswell.
    vt exec, ex governemt car, only complaint is the gearstick button has popped out of the retainer, but is still usable, paint not look after but still in good nick,
    vt exec, was bought as a new tafe hack car, 300,000km on the clock still runs great, interior in real good nick, obviously been in a good accident from panel and paint misalignment and colour match
    thats just from my experience, dont get me wrong, if ford had a half descent looking bf wagon i probably would have bought it over my vz, great engine and i like the semi-manual in them because hol/ford don't like making manual wagons
    Jan 2005
    QLD
    Im still thinking about it.. Like I said im no Ford or Holden hardcore freak, but I have seen a crapload of VTs with interiors that have not lasted.. About 80% of them have the rear vents that are broken, centre console where shifter is scratched, audio controls on steering wheel buttons missing etc. This is from what ive seen. But I guess, when you buy a car of this age, you cant be too picky or choosy.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Most of the wagons i have seen are in that way also.
    Think they are mostly old lease cars bit miss treated inside.
    minux's Avatar
    minux is offline Infidel Bear
    300rwkw FG G6ET/2011 Sti Spec R Hatch
    Mini Putt 2 Champion!
    Feb 2005
    go the falcon, you wont regret it.
    If it were an 8, i'd say go the commy, but the I6 slaughters any holden 6 especially for towing.
    "Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind."
    - Theodor Seuss Geisel
  1. Commodore S ....Commodore SS... is there a difference..??
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-12-2009, 03:23 PM
  2. Fitting XF Fairmont Ghia dash to VL
    By VQXTC in forum VL Holden Commodore (1986 - 1988)
    Last Post: 19-08-2008, 09:14 PM
  3. Do VN V6 Commodore injectors fit a VR V6 commodore
    By ozzybloke01 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-09-2007, 04:43 PM
  4. VN commodore exhaust into VR commodore
    By The Darkness in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-11-2006, 09:38 PM
  5. vn ss vs fairmont
    By mike_is_bored316 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-05-2006, 11:50 PM
