Results 1 to 9 of 9
Thread: door handle
    executive vt 5.0lt
    Feb 2005
    west suburbs
    Default door handle
    my wife went to open the passenger door ,and something broke inside the door, and the door wont open, how hard is this to fix the handle still lifts up and down but does nothing
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    The handle itself has most likely broken, they are plastic and it is a common fault. You will need to replace the handle if it is broken. The door trim needs to be removed to access the handle.
    MY RIDE
    VT C/SPORT 5.0L 5Spd
    Aug 2008
    If door still open from the inside, then you have brioken the exterior handle. The problem is well known and replacement door handles(in revised configuration) are available from holden dealers, and aftermarket.
    Problem is that the part needs to be painted, they come in grey plastic colour unprimed.
    Assuming you have the replacement colour coded part. The replacement does not take long. remove door trim, peal back plastic sheet at top left corner.
    Removal and replacement is straight forward.
    Time to complete job would be less than 1 hour including cleanup.
    Consuming part is sourcing handle and getting item painted.
    When I did mine i replaced all handles at once, got rid of all nail scratchs and lifting clear.
    executive vt 5.0lt
    Feb 2005
    west suburbs
    Quote Originally Posted by njnathan View Post
    thanks for that seems like a easy job to do just got to get a new handle and paint
    executive vt 5.0lt
    Feb 2005
    west suburbs
    finally , got the guts to have a look today ,all came apart easy enought, look out for those hidden screws, lol. my mate had the same prob so last week he pulled his apart and it was theactuating rod had dislodged easy fix but mine the handle support has snapped so have to get new handle.there is a paint place here that puts paint in a spray can here so looks like i have a job on soon also those window winder handels i got one off but no go with the others using the rag method
    Mick1988's Avatar
    Mick1988 is offline W.A. Cruise Moderator
    Too many to list......
    Apr 2008
    Perth, Western Australia
    If you remove the handle you might be able to find a way to modify it to keep it working. What colour is your car? Might be able to find someone wrecking one in the paper with a working handle in the right colour.
    executive vt 5.0lt
    Feb 2005
    west suburbs
    the colour is tundra perl' a gray colour the handle is stuffed no way to bodgie it to work
    Mick1988's Avatar
    Apr 2008
    executive vt 5.0lt
    Feb 2005
    west suburbs
    those are silver
  1. Door Handle removal
    By AlpineRaven in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-10-2006, 08:06 PM
  2. Door Handle broke!!!
    By dazamaz in forum General
    Last Post: 24-08-2006, 09:47 PM
  3. vt door handle
    By VTPREDATOR in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-03-2006, 12:21 PM
  4. new door handle
    By rekless driver in forum General
    Last Post: 31-01-2006, 09:35 PM
  5. Before I Go Taking The Door To Pieces!... Whats The Go With The Door Handle??
    By holden#1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-01-2006, 09:37 PM
