Results 1 to 7 of 7
Thread: how to remove little spacer thing.
    vt
    Oct 2008
    Default how to remove little spacer thing.
    does anyone know how to remove that spacer kind of thing that is above both your rear quarter panels.. its about 45cm long, 3cm in width;
    CHECK OUT THE ATTACHED PIC.. CHEERS
    Attached Thumbnails Attached Thumbnails how to remove little spacer thing.-p1000040eo5.jpg
    dijm8's Avatar
    dijm8 is offline What You Looking At
    VZ SS LS3
    Jun 2006
    VT S V6 LPG
    Jun 2006
    It is bolted and glued on, quite hard to get off without snapping it as it is made out of cast alloy. There is a 10mm bolt inside the car behind the plastic trim where your seat belt is and the rest is glued.
    VTS5's Avatar
    VTS5 is offline TechJunkie
    '97 VT Spack 5 Speed
    Jul 2005
    Sth.East\Melb
    Quote Originally Posted by macksvt View Post
    There u go ..... Good luck
    vt
    Oct 2008
    ok.......
    hah! do they remove that part if you were to get your car sprayed professionally ?
    is it worth taking off ? i have to if i want to paint the car dont i?
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Yes you can remove it quite easily, I have done so on mine with no problems.
    Undo the bolt behind it and use a piece of fishing line to slice through the backing
    VT S V6 LPG
    Jun 2006
    i didnt bother when i resprayed my car and have had no problems. more hassle to remove.
  1. Mace manifold insulator & plenum spacer
    By muzzz89 in forum V6 Development And Modification
    Last Post: 31-01-2012, 10:50 AM
  2. LS1 Valve Cover Spacer
    By chappy in forum The Pub
    Last Post: 17-04-2007, 07:44 PM
  3. Water pump spacer plate wear
    By crazyspoon05 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-12-2006, 07:00 PM
  4. spacer for 6x9s
    By adams vn in forum Car Audio
    Last Post: 15-09-2006, 03:01 PM
  5. papper spacer thingy in throttle thing
    By sexcvn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-02-2006, 08:56 PM
