hey folks,
i cant seem to get the mirrors off...
ive undone the 2 10mm bolts, is it stuck on their with some sticky crap ?
cheers
REMOVE
1. Disconnect battery earth lead.
2. Remove the mirror inner cover cap (1) by
gently prying the cap away from the door.
NOTE: The inner cover cap retaining clip (3) can
only be used once.
3. Remove door inner trim panel (2),
4. Remove the three screws (2) securing the
exterior rear view mirror (1) to the door and,
while supporting the mirror, disconnect the
mirror wiring harness connector (3).
it should then just come away ??
when you undo the two bolts youll notice black foam there.
under the black foam is another bolt
3 bolts all up
I bought a set of cheap offset screwdrivers, $3 from Bunnings, they have a 90 degree offset, so I got the mirrors off without removing the door trim, saved heaps of time.
